NEW PMR CHANNELS
handyguy2002
NEW PMR CHANNELS
Post by handyguy2002 » 25 Nov 2017, 14:22
HI GUYS found this the other day and thought id share it with you
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
stratocaster
Re: NEW PMR CHANNELS
Post by stratocaster » 12 Jan 2018, 08:37
That just registers on the scanner for dpmr as dPMR 446.00312 to 446.19687
pete_uk
Post by pete_uk » 12 Jan 2018, 17:18
Are these Ofcom official or enthusiast based?
stratocaster
Post by stratocaster » 12 Jan 2018, 18:08
They'll be Ofcom approved. Have to set scanner to 0.01khz to enter the dpmr frequencies.
radiosification
Post by radiosification » 15 Jan 2018, 14:36
stratocaster wrote:
12 Jan 2018, 08:37
Unless you have the AOR AR-DV1 then you won't be able to decode the dPMR channels anyway so I wouldn't bother putting them in. You can just put in the 16 analogue/DMR frequencies and cover everything you'll be able to decode
stratocaster
Post by stratocaster » 16 Jan 2018, 08:26
radiosification wrote:
15 Jan 2018, 14:36
stratocaster wrote:
12 Jan 2018, 08:37
As it happens, I do own a DV1! Hence why I put in the dPMR frequencies.
stratocaster
Post by stratocaster » 16 Jan 2018, 10:53
What is the misnumbering with ch 30 on the dPMR list? Surely that should read 446.184375 not 446.184373?
Minus1
Post by Minus1 » 21 Jan 2018, 08:44
pete_uk wrote:
12 Jan 2018, 17:18
OFCOM just do as they told by the 'gods' in the EU/ECC/CEPT and doubtless other acronyms containing "E":
http://www.erodocdb.dk/Docs/doc98/offic ... EC1505.PDF
stratocaster
Post by stratocaster » 22 Jan 2018, 12:26
Minus1 wrote:
21 Jan 2018, 08:44
pete_uk wrote:
12 Jan 2018, 17:18
I always knew that E's were bad!! :D
pete_uk
Post by pete_uk » 19 Feb 2018, 15:39
OK, so what to put for Colour code (I left at 1 - slot 1) and the contact name? Group call 1 or 9?
I don't think Hytera do a mode that lets anything g in??
