LINCOIN 2
- Mudslinger
Re: LINCOIN 2
I think you will need a Frequency counter to set it correctly Tom as each radio will need to be set on a different number to be on frequency.
Its a bit like the old radios where you have the adjustment in one position on one, and a slightly different position for another radio. Down to tolerances in components etc.
The engineering menu isn't really meant for use by normal users, only radio techs etc.
- astradyne
Re: LINCOIN 2
Not the same radio, but I set my old Alinco 135 up using the menu and my ICOM 706 which I knew was bang on frequency. I adjusted the setting value on the 135 until I got a constant feedback tone on the 706. I set up USB and LSB this way and it was spot on after that.
- Call Sign: BPO6O
Re: LINCOIN 2
Thanks chaps will let you no when its right my mate said its to moving down .but how far that's the rouble .
Re: LINCOIN 2
Maybe yours is spot on and your mates is off?
- astradyne
Re: LINCOIN 2
This.
If your mate's using a top notch HF set then maybe your Lincoln is off. If he's using a CRT 3900 then don't take his word for it.
Best thing to do before whipping the lids off is to get several reports off different people. Remember to allow your radio plenty of time to warm up and settle on frequency first.
- Call Sign: BPO6O
LINCOIN 2
Hi chaps after getting this president Lincoln 2 it was way off on usb could not tune in anything .Went in the menu as shown on YouTube to re tune the number showing was 818 ended up turning it up to 860 its all most at 12 o'clock now and receiving ok .should I have had to turn it that far to get it in or as something been turned in side before I got it and is there any photos of the pc board showing the tuning points thanks chaps
- Call Sign: BPO6O
Re: LINCOIN 2
Did the best thing sent it to the top man Nick sorted it fast its on its way back all singing and dancing thanks again Nick
- Call Sign: BPO6O
Re: LINCOIN 2
I did send it to nick last week sorted magic fingers ok now
- astradyne
Re: LINCOIN 2
I've got a 2830 here that needs the output sorting out (It hasn't any). I'll get around to sending it over to Nick at some point along with the Galaxy DX-2547 which has been sat here for an eternity waiting to be sent to him.
Something always crops up this end...
Users browsing this forum: Google Adsense [Bot] and 3 guests
