kl203p- new version ?
gmham
Call Sign: 108TM154
Post by gmham »
Guys anyone aware off any tech changes to the latest blue colored version off the kl203p linear over the older red version ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Re: kl203p- new version ?
Post by ch25 »
Same crap splatterbox.
gmham
Call Sign: 108TM154
Post by gmham »
ok cheers for your input !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
mrpsychopath
Call Sign: 108tm1313
Post by mrpsychopath »
Was told they are a lot better than the bv150s that i use. Had one of red ones before lasted 4 days till it popped. Hence why i now have bv150 splatterbox.
Post by ch25 »
kl203 works acceptable as long as you do not exceed 2W AM/FM and 10-12 SSB on input. Looks not that bad on the scope and spectrum analyser.
More drive, more distortion. Tested by myself.
gmham
Call Sign: 108TM154
Post by gmham »
ok cheers
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
prettypolly
Call Sign: 26FB185
Post by prettypolly »
watch for the bf199 tranny pre amp goes pop if over driven ..
gmham
Call Sign: 108TM154
Post by gmham »
okay cheers so 12watts max on ssb input.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Post by ch25 »
For longer talking I suggest to put 12cm fan on top of it.
Mudslinger
Post by Mudslinger »
I normally put around 7 watts AM/FM and 18Watts SSB into mine and have had no issues.
Just be careful using it with a radio such as a PC-999 Grant, as they might give 8 watts on deadkey but with modulation power will rise high enough to hill the amp.
Post by ch25 »
Mudslinger wrote: 01 Jan 2018, 14:51 I normally put around 7 watts AM/FM and 18Watts SSB into mine and have had no issues.
You just have no idea of amout of garbage going out when you overdrive that box. Lucky, I do not have you in the neighbourhood.
Mudslinger
Well according to the specs I am not overdriving it.
No complaints yet, exept on one occasion a radio I was using had a fault.
I do use a reasonably good low pass filter.
163TM847
Post by 163TM847 »
ch25 wrote: 01 Jan 2018, 15:07
Finally, Someone who agrees with me that the KL203 [MOSFET] is an awful amp, Just by seeing the SWR jump when powered on indicates the amount of rubbish being spewed out of them, I dont have the pleasure of owning a spectrum analyser but i would love to see the results of a KL203 with 5-15w input.
Buick Mackane
Post by Buick Mackane »
I bought one new and had SWR Problems, Even with an inline filter, Personally i'd avoid them at all cost, They spew out more crap than spamdemon :lol:
Post by ch25 »
Mudslinger wrote: 01 Jan 2018, 16:15 Well according to the specs I am not overdriving it.
Specs given by rmitaly are pure b$. Similar to zetagi etc.
Black Spirit wrote: 01 Jan 2018, 16:33I dont have the pleasure of owning a spectrum analyser but i would love to see the results of a KL203 with 5-15w input.
I sold my analyser over year ago since I do not play with those toys anymore, but I still have a scope and when I get one of those boxes I will make some screenshots.
