Rotel 240 microphone problem
Classic
Post by Classic »
Hi guys got a rotel 240 and i tried wiring a mic up but it just keying its self up. I've tried different mics and they are wired up to the same type of radio what could this be ?
Classic
Re: Rotel 240 microphone problem
Post by Classic »
It's ok i've sorted it thanks.
Buick Mackane
Moderator
Moderator
Post by Buick Mackane »
What was the problem ?
speeddemon
Post by speeddemon »
Me thinkz he more than likely Got tx / rx mic wires wired to wrong pins. :ugeek: .
Classic
Post by Classic »
I got the wiring right but someone had changed the wiring inside the radio and so i had to figure out which wire went where on the plug.
speeddemon
Hi classic gd man glad you got all sorted out and radio working .cheers
Classic
Post by Classic »
speeddemon wrote: 01 Dec 2017, 16:29 Hi classic gd man glad you got all sorted out and radio working .cheers
Yeah it was a bit frustrating but got there in the end.
Post by The Collector »
I've seen that where they've got quite a few radios and have say wired the Cybernet-boarded ones so they can use their favourite Uniden-wired mic' on them without having to use a cross-over adapter lead if changing radios regularly.
