Edinburgh buses or trams?
Anyone have any frequencies for these? Also looking if there's any for fireworks display tonight? Any help would be much appreciated?
Re: Edinburgh buses or trams?
Busses on band 3. Trams 163/164mhz. All covered in detail in the past and detailed on the wtr if you search.
What is band 3 please ?
Thanks SK007
Thanks SK007
Band 3 is between 175 and 225 MHz
Normally analog trunked systems covering large areas.
But believe there is going to be DMR available in this band soon.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Thanks mate. Any specific frequency? I'm using a baofeng
Dozens. To many to list. Search 176mhz to 180mhz at 12.5khz steps, lock out the data channels, and in a couple of days you will find what you want.
I gave up on the street trains and buses due to plenty of the pre transmission prolonged "warbling engine" sound, making the DMR (Road drill) sound bearable!
You can never have enough radios!
There's no specific frequency?
