Radioddity GD-77
kilimax
Call Sign: GM0BRJ
Re: Radioddity GD-77
Post by kilimax » 14 Aug 2017, 18:34
My GD-77 arrived today.
No extra duty to pay which was great. It's very early days but I have to say the quality is quite impressive considering the price. While not as solid as my Retevis RT-82, it has a good feel to it and It's also smaller in size. The screen is not as good as the RT-82 but is very usable.
Both my Retevis RT-3 and this new radio can use the same charging base so that's a bonus.
Programming software is basic but it works. If you can program a TYT or Retrevis DMR, this shouldn't be too much bother. So far, I've programmed a couple of analogue repeaters and one of the DMR simplex frequencies. The basic DMR channel setup (Amateur UHF DH1) works with my Retevis RT-82, my RT-3 and the GD-77 so at a basic level, it's compatible.
More to test but so far, for just over $100 delivered, it's an absolute bargain!
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Post by Admiral » 14 Aug 2017, 20:20
Does it have better ears than your RT-82?
kilimax
Call Sign: GM0BRJ
Post by kilimax » 14 Aug 2017, 20:59
Admiral wrote:Does it have better ears than your RT-82?
It's better than my "first" RT-82 but my replacement is spot on now.
Kilimax - Drew
BK
Post by BK » 14 Aug 2017, 22:52
kilimax wrote:It's better than my "first" RT-82 but my replacement is spot on now.
On the RT82, do you get a loud 'pop' at the start of the audio when receiving DMR? Mine does this, and my old MD380 did it too. It's particularly distracting when a station is dropping in and out of repeater coverage (even though your reception of the repeater is solid) because you get pops all over the place, not when the station drops out but when it comes back again.
Post by Admiral » 14 Aug 2017, 23:07
Paul has also got his GD-77.
https://www.youtube.com/watch?v=Z8c7XEJ-ap4
kilimax
Call Sign: GM0BRJ
Post by kilimax » 15 Aug 2017, 10:58
Yes, it does do that, as does my RT-3 and most other stations, even listening via the DV-Mini. I hear this often.
Most likely just the digital equivalent to drop out and receiver reacquiring the signal.
Kilimax - Drew
kilimax
Call Sign: GM0BRJ
Post by kilimax » 15 Aug 2017, 11:32
Admiral wrote:Paul has also got his GD-77.
Broadly in line with what I have found so far.
Kilimax - Drew
BK
Post by BK » 15 Aug 2017, 16:27
kilimax wrote:
BK wrote:On the RT82, do you get a loud 'pop' at the start of the audio when receiving DMR? Mine does this, and my old MD380 did it too. It's particularly distracting when a station is dropping in and out of repeater coverage (even though your reception of the repeater is solid) because you get pops all over the place, not when the station drops out but when it comes back again.
OK, thanks for that. I can't believe the likes of Motorola would do this, it should be an easy problem to solve. I don't recall my SDR dongle ever doing it.
kilimax
Call Sign: GM0BRJ
Post by kilimax » 15 Aug 2017, 17:22
I don't have access to a Motorola here to test so cannot comment. I tend to find the popping sound is most audible when listening through one of the DMR repeaters. I don't get anything when using simplex but again, signals are strong both ways so there's no drop out.
Kilimax - Drew
sec1223
Post by sec1223 » 15 Aug 2017, 19:33
think il buy one.
cant stand IGNORANT b******ds
kilimax
Call Sign: GM0BRJ
Post by kilimax » 02 Sep 2017, 21:16
Anyone thinking of buying one of these, Amazon have them in stock.
https://www.amazon.co.uk/dp/B074HX8T9K/ ... QzbXDX9AXN
For £77 delivered, I've ordered another one to play about with outside of the Amateur bands.
Kilimax - Drew
delboyonline
Post by delboyonline » 06 Nov 2017, 17:25
Just picked one up myself, great little radio for the price.
DrumGeek
Post by DrumGeek » 07 Nov 2017, 16:11
Hi All,
Does anyone know if this radio does proper dual receive?
i.e. will it hear both VFOa and VFOb at the same time with either 2 analogue freqs, 1 analogue and 1 digital, or 2 digital?
Thanks,
Mark...
Uniden BCD396T | Uniden UBC780 XLT | Commtel COM215 | Realistic Pro-35 | Realtek RTL820 SDR x2 | SDR Play RSP2 | PiAware/Flightaware ADS-B Receiver | Yaesu FT-817ND | Wouxun KG-UV8D | Tytera MD-380 | Radioddity GD-77
Steve B
Post by Steve B » 07 Nov 2017, 22:12
Someone I know locally has gotten one of these recently... previously they had an FM baofeng. Now with it he comes out stronger than ever before, signal screaming through the walls. Albeit this is with FM.
30-Tango-Mike-003
Good Christian Boys: Midland G7 XTR "Street-Legal" PMR 3-watter - Kenwood UBZ-LJ8 PMR446 - Intek FM548SX (With Homogolation boys 8) )
Naughty Boys: Philips 25W FM1100 UHF w/PA4DEN - Baofeng UV5RA, Superstar 360FM (My good one!) w/ CTE 747 100W Amp
k1lho
Call Sign: K1lho
Post by k1lho » 13 Nov 2017, 06:05
I purchased a GD-77 and think it's GD radio. It's codeplug data format is not compatible with the the much more popular MD-380.
The DG-77 requires receive groups in addition to contacts. This significantly complicates programing. Even worse, you can only have 16 receive groups which may be less than the number of contacts. If you place several contacts in a single receive group, you'll be listening to several TG's at the same time with no way of differentiating the dialogue from each.
