What on earth could this be
- superstar
I found this fidelity 1000 on the boot sale for a fiver, on the back there’s a switch, roger beep I thought, all it does is make a whining sound when switched on, thought I’d have a look inside an found this board taped up and rigged up to the switch with loads of wires, oh the rig works fine with the switch off, wad ya rekon lads?
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- Buick Mackane
Re: What on earth could this be
Never mind the board, Its this bit i'm concerned about
- superstar
Buick Mackane wrote: ↑10 Nov 2017, 19:47 Never mind the board, Its this bit i'm concerned about
Cb handle
Cb handle
- sickboy
- Tigersaw
- Call Sign: GW6RRL
The SL1496C is a balanced modulator, so it could be a SSB board.
- Auldgeek
- Call Sign: GM0BRJ
In a Fidelity 1000?
I say sir, I just has to ask. Are you on some sort of psychedelic mix because, man, that's so, like, out there.....
- Tigersaw
- Call Sign: GW6RRL
Well either that or a board to make you sound like a robot
- Buick Mackane
Thats what i was thinking drew, Its just to wacko to comprehend
- Auldgeek
- Call Sign: GM0BRJ
It will be some sort of early echo/voice reverb board or some sh!t like that
- astradyne
The words "Fidelity 1000" and "works fine" do not belong in the same paragraph.
Double balanced modulator IC could be a voice inverter/scrambler, There's no filters for it to to be an rf speech processor.
W8JI
- Mudslinger
Someone must have fitted it for a laugh.
I cannot think of any other reason, unless it is to improve bleedover rejection
- superstar
The deal clincher at the boot sale was that it was mounted on one of them plastic rig stands you could buy years ago, must of been someone’s pride and joy back in the day
Cb handle
Cb handle
- Call Sign: 108tm1313
Did you keep the stand, i was looking for one.
- superstar
Yep I did keep the stand, you don’t see them often nowadays, they look pretty neat and are angled just right, Spode I’d better keep it though
Cb handle
Cb handle
