So thats how you can't be ass'ed answering your PM's ? Too busy buying gear on the bay
What CB/11m Radio Stuff did you buy today? (2017)
- Buick Mackane
Re: What CB/11m Radio Stuff did you buy today? (2017)
- ROTEL240
Purchases a CRT ss9900 I have heard plenty of them on air do I bought one Friday so I will give it a whirl, just after a programming lead to set it up how I want.
- superstar
Picked up this 7 digit frequency counter a couple of weeks back, works good and looks new old stock, anyone know much about them?
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
Cb handle
- gmham
- Call Sign: 108TM154
https://imgur.com/a/kXP8E
Just arrived today, took a chance one morning during the week , had only just been listed by a company that looked like a clearance company, was originaly asking £95, put in an offer off £75 and got it, mk2 with so far not one mod found on it, original bezel and faceplate / bracket and thumb screws. the rear serial plaque still has its original plastic over the thing..only downside was no original cobra coffin mic but will sort that out soon enough !! bought another one at the tail end off last week, another lovely well sorted super high to super low mk2 from a well respected tm1 member from wales. so now got two
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: 108tm1313
You deffo not shopping on evilbay
- gmham
Yep but has taken me years and years and years and over 917 transactions and a lot off waisted dosh inbetween to get my " one in a million " !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
Glad you got what you wanted then.
- gmham
Cheers mate yep did not set out for two off them but at 75quid this additional one was certainly worth a try ?! Knew it looked decent in the photos but dare say we have all been there before ! So was obviously delighted when it arrived in the condition its in and the fact is still standard. At least with it being standard anything required mod wise can be done by someone you trust when required !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- astradyne
Well done gmham. For £75 that's a stunning set.
Not in the same league, but I picked this odd looking dummy load for a steal on a best offer. Not seen one with two connections before. I'm guessing it's 100W constant and 500W short TX if the lettering is correct. It actually works too!
Nothing special but bagged this while in Walmart last week on Holiday, cheap as chips so I could not resist
- Mudslinger
Maxcom 30E
pretty tidy, but needs a replacement switch.
I like these old Maxcom Muppet sets.
- Auldgeek
- Call Sign: GM0BRJ
I'm not normally a collector of UK40 fm only radios but as it happens, I had a chance to buy both a Fidelity 2000 & a 2001. The 2000 I believe is a decent Cybernet chassis and the 2001 is the same as the chassis on the Japanese made Amstrad 901.
Both radios are in superb condition. Some pictures of the 2001.
Boxed with all of the original paperwork. Manual, warranty card, aerial installation guide, even an application for an extended warranty. Power lead looks as though it has been wrapped up since new and the microphone looks unused. A small mark beside the volume control stops it from being mint.
I now have boxed examples of all the UK40 radios I owned and used during the early eighties, so from a nostalgic perspective, I'm quite chuffed.
I used a 42 channel Fid2000 for a year or so and found it to be great little radio. Was never as keen on the looks of the later 2001 as the knobs looked weedy and too far apart compared to the 2000. I stuck to a Harvard 420m which was basically the same as the 2000 after that for a couple of years.
A good find
A good find
- Buick Mackane
I hope the extra 2 channels weren't on the ten metre band, Nawty nawty
- Auldgeek
- Call Sign: GM0BRJ
I know what you mean about the knobs on the later model but it worked well, probably had a slightly better receiver than the 2000.The Collector wrote: ↑13 Nov 2017, 23:06 I used a 42 channel Fid2000 for a year or so and found it to be great little radio. Was never as keen on the looks of the later 2001 as the knobs looked weedy and too far apart compared to the 2000. I stuck to a Harvard 420m which was basically the same as the 2000 after that for a couple of years.
A good find
Never owned any Harvard but liked the look of the 420m.
