Base antenna for 446 mhz help needed
- WARLOCK
- Call Sign: 26TM134
just bought and received a base antenna for PMR446 Mhz, e/bay item number 302491369589 from stanislavpalo130 when i tested the antenna i find there is a short between the inner section and outer section of the coax cable should this be so ???
- Call Sign: G4RMT
Re: Base antenna for 446 mhz help needed
I bought one from him too, and it's sitting here and I can confirm it's a DC grounded antenna, so the short is correct. Mine actually works rather well on 433 and 453 too! Mine is 1.17 VSWR at 448.1MHz at it's best on the analyser.
- gmham
- Call Sign: 108TM154
So if it's showing it's lowest vswr on 448.1mhz can I ask what it's showing on it's intended design freq off 446mhz ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Call Sign: G4RMT
1.2 I spotted these about a year ago and have had a UHF high band one and the 446, and the tuning is quite sharp, it's not got much response at any other frequency, then suddenly takes a dive right down. It's handy for 449MHz too. I tried to make something very similar, and found that inside mm accuracy was critical at UHF, and while with wideband designs it doesn't matter.
EDIT - I've just spotted that I mixed them up. The ones I have are these ones 302501691331 (in 446 and 453 versions)
Which is a half wave design, compared to the 5/8th one this post relates to - mine of course is not tenable, being sealed in the tube, while the ⅝ version is.
He makes decent quality kit, and while I make a few myself, his are neater and surprisingly light!
- Admiral
- Call Sign: 26TM157
"DC ground coil for full static protection"
He put a clue in the listing, you will still need to make sure you ground it though. Plus, it has an N connector, so make sure you get one of those on the end of your coax as adaptors outdoors will invite moisture and could be lossy if they are ten bob Chinese things.
I love that guy's antennas. They are good ****. They work on principles of gamma match magic. Bought a yagi from him a while ago and have made 100+ mile contacts with it.WARLOCK wrote:just bought and received a base antenna for PMR446 Mhz, e/bay item number 302491369589 from stanislavpalo130 when i tested the antenna i find there is a short between the inner section and outer section of the coax cable should this be so ???
30-Tango-Mike-003
Good Christian Boys: Midland G7 XTR "Street-Legal" PMR 3-watter - Kenwood UBZ-LJ8 PMR446 - Intek FM548SX (With Homogolation boys )
Naughty Boys: Philips 25W FM1100 UHF w/PA4DEN - Baofeng UV5RA, Superstar 360FM (My good one!) w/ CTE 747 100W Amp
- New User
Best out the box antenna for 446 that I’ve used is a w2000 not a v2000 the Watson model works way better on 446 ,also it’s a great scanning antenna as it covers a lot of bands ,
Enjoy
Enjoy
The Sirio PMR446 antenna is very good, it also covers 70cms and of course LPD433 as well.
- Farty
I use a 440 J pole adjusted for 446. Forks nicely, cheap as chips.
