New 11mtr vertical required ?
- NUBSTER
- Call Sign: 26TM545
Re: New 11mtr vertical required ?
Did you wrap your swish curtain rails with wet string Dave ? , I've been told it works .......
- Bigdave
No to be fair, but are give it a try thanx. Also read about swr grease I guess that's worth a try as well ........................
26 TM 1248
WINNER of INB4TL, the big battle edition 16/07/23
OFTEN IMITATED,BUT NEVER INTIMIDATED.
WINNER of INB4TL,the no interest edition 18/03/24
- Auldgeek
- Call Sign: GM0BRJ
Ah, the good old swr grease. Turns any old sh1te into a top performing antenna. Any respectable antenna fiddler shouldn't be without a tub.Bigdave wrote:No to be fair, but are give it a try thanx. Also read about swr grease I guess that's worth a try as well ........................
- MrWeetabix
- Admin
- Call Sign: 26TM175
So them GMHam, what did you go for fella? :-)
- gmham
- Call Sign: 108TM154
Well as us Scotsmen are known to like saving the odd penny or two decided to save my dosh and put an old cushcraft r6000 20-15-10 mtr vertical into service that I had kicking around the garage, in the process off cleaning it all up before launch day !! hopefully it will work okay but if not the buy it now button on the sirio 827 is still flashing away at me !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
