Wiring a KPO NM 532 Power Mic to Superstar 6900N
HighwayPatrol
Call Sign: 26CT2325
Post by HighwayPatrol » 02 Oct 2017, 23:51
Hello everyone,
I have graduated from a Team Roadcom FS to a Superstar 6900N. I have a KPO NM 532 Power mic but have no idea what wire goes where. I know that one wire should not be soldered on the plug as it is 5+ volts. The mic wire colours are blue, white, red and braid.
Anyone else on here have the same mic and rig ?
Thanks for any help.
Paul 26CT2325
Ex 934Mhz Club UK Member.
Member of Charlie Tango Group
26 CT 2325
Baofeng UV 5R
Superstar 6900N.
astradyne
Moderator
Moderator
Re: Wiring a KPO NM 532 Power Mic to Superstar 6900N
Post by astradyne » 09 Oct 2017, 12:43
Hi Paul.
The braid should be soldered to pin one. The audio (the wire with the braid wrapped around it) goes to pin two. Pin three is transmit. Not sure as to the colour coding on the Mic, but try the two remaining wires on pin three. If it's not correct the first time (Radio doesn't TX) just swap to the remaining wire.
Do not connect any wires to pin four. This is the +5V from the radio to power the stock mic.
HighwayPatrol
Call Sign: 26CT2325
Post by HighwayPatrol » 11 Oct 2017, 13:41
Hello Astradyne,
thank you foe your help and info on this mic. When i bought it, it was already wired up but when plugged in, it was already keyed up and when i pressed the PTT it unkeyed but no mod. I will try re wiring it with the info u have given and see if i can get it working.
Thanks again
Paul
26 CT 2325
Baofeng UV 5R
Superstar 6900N.
astradyne
Moderator
Moderator
Post by astradyne » 11 Oct 2017, 22:06
It's wired Cybernet by the sound of it. Just be very careful with pin 4. Don't attach any wires to it or you will cause serious damage to the radio.
HighwayPatrol
Call Sign: 26CT2325
Post by HighwayPatrol » 12 Oct 2017, 08:12
Thanks for the warning. I might jujst send it off and have it wired professionally. I dont seem to have the skill anymore for wiring mics and knowing my luck, i would end up damaging the rig.
26 CT 2325
Baofeng UV 5R
Superstar 6900N.
Users browsing this forum: Google Adsense [Bot] and 5 guests
