New 11mtr vertical required ?
- gmham
- Call Sign: 108TM154
In the market for a new 10/11mtr vertical. Thinking off the Sirio 827 / Sirio 2016 etc.. any difference between the two ? Any strengthening mods required on them ? Anything else worth considering .. Tornado 27 new ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
Re: New 11mtr vertical required ?
2016 need strengthening of L shaped mast mount. Usually bend under a wind. Otherwise is a good antenna.
- gmham
Okay cheers so might be better with the 827 ?
anyone here owned them both be interested how they compare performance wise ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
I doubt there is anyone had them three at the same time, mounted at the same height to compare If not, it will be just guessing.
- gmham
Yep sorry really meant between the 827 and the 2016..
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
Hard to say.
When i test different antennas or tune them I use low power transmitter located circa 500m from antenna. Always same place, same height and power.
According to that test I can tell if one antenna is better or worst than the other.
- mof000
Oggy has just done a review of the Vortex quasar v2
https://www.youtube.com/watch?v=Uq0ulNbKlWo&t=75s
Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
Am I right in thinking that Shogun's RX wasn't quite right on the vid?
- ROTEL240
Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
- NightProwler
- Call Sign: 163TM186
I'll second that. I put one up for a friend of mine a while back and the build quality is excellentROTEL240 wrote:Dont discount the cheaper sirio GPE27 5/8th wave its a well made cracking dx antenna
- Oggy
I would like to see your curtain rail.....shallow, Shallow Halch25 wrote:Shallow review I would say. Similar results you can get by connecting curtain rail to radio.
- WARLOCK
- Call Sign: 26TM134
Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
- Oggy
I look forward to his "Curtain Rail" review......maybe he will share a youtube link?.WARLOCK wrote:Usual ch25 statement shallow shallow as it is still at least this time he has put forward a better antenna in his mind HIS CURTAIN RAIL now all we need to know is where can we buy one from B&Q may be ???
Just maybe the CR special will match this antenna with just 3 watts of input....I wait with excitement.
I see he has plenty to say when ever I get mentioned.
viewtopic.php?f=2&t=54062
- Bigdave
I went for the swish curtain rail as it was more expensive, so it must be much better can't get the fecking swr down though........................
26 TM 1248
WINNER of INB4TL, the big battle edition 16/07/23
OFTEN IMITATED,BUT NEVER INTIMIDATED.
WINNER of INB4TL,the no interest edition 18/03/24
