Baofeng BF-888s Review
o][o
Re: Baofeng BF-888s Review
Post by o][o »
I'm unable to activate vox in any of my 4 radios. It is activated from software and when trying to activate from radio by holding down ptt and moni, nothing happens.
There is following list of functions in the manual but vox, alarm (whatever it is) and temporary voice prompt deactivation isn't working.
SUMMARY OF MENU FUNCTION ACTIVATION
Ch. 1-5, Press / Hold both PTT and MONI, and Power ON
VOX - ON / OFF
Ch. 10, Press / Hold both PTT and MONI, and Power ON
Voice Prompt - ON / OFF
Ch. 11, Press / Hold both PTT and MONI, and Power ON
Alarm Function ON / OFF (if selected via SW)
Ch. 12, Press / Hold both PTT and MONI, and Power ON
Locks Transmitter ON (Power cycle to reset)
Ch. 15, Press / Hold both PTT and MONI, and Power ON
Change Language (CHI / ENG)
Ch. 16, Press / Hold both PTT and MONI, and Power ON
Scan ON / OFF (if option set via software)
Ch. 1-16, Press / Hold MONI only and Power ON
Deactivates Voice Prompt for that session only
LeakyFeeder
Post by LeakyFeeder »
Bogget is yer man for all.things BF888... but he hasnt been on here for a few years
bigpeter666
Post by bigpeter666 »
I have several of these in black yellow blue and red brilliant radios all on 446 I swear by them
Powermax
Post by Powermax »
Does anyone know how these sets compare with TTI 1446 radios? (sensitivity, functions)
I have some TTI sets but they are only 0.5W, though I do use them with Nagoya 771 antennas (they don't fit flush to the unit so look a bit messy)
Would the 888's with a stock antenna and the higher power outperform 0.5W into a 771?
bigpeter666
these radios are brilliant i have several versions of the baofengs
bugsy
Post by bugsy »
Does this now mean we can use 16 channels on analogue??
be great to add a few to my bofungs
http://kenwoodcommunications.co.uk/comm ... -446/freq/
http://kenwoodcommunications.co.uk/file ... _JT_KB.pdf
anyone clarify?
gmham
Call Sign: 108TM154
Post by gmham »
The good thing about having extra 446mhz channels will be that most kids / businesses will already been using the 8 ch versions and it's only the rest off us in the know that are aware off the secret second set !!!
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
AlfieDivine1
Call Sign: 26CT2369
Post by AlfieDivine1 »
I have a list of PMR 446 users / 449 simple site licensed users for the shops here in Folkestone
AlfieDivine1
Call Sign: 26CT2369
There is only one PMR 446 Channel, Ch 3 in and it is scrambled :?
I think it could be Asdas security or some sort, but Asdas are nationwide allocated for 449.400
friendly1uk
Post by friendly1uk »
Quite disappointed with my latest set. The speaker isn't as good as my earlier model. Sounding more like my tiny uv3r than the 888s I'm used to.
My early 888s has the red lines on the rotary switchgear, a shinier box, bigger baofeng branding and 3 battery connections. The lighter battery in the new ones lasted longer than they claimed though. Days.
thelad
Post by thelad »
Load of crap now rather have a Md380 :-))
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Call Sign: G4RMT
Post by paulears »
I've ordered some of the new BF-999 to try out, but over the years, I've noticed that each batch can be quite different when they switch to different speakers, or other swapped components. Inside, most parts are generic and clearly batched - so sometimes performance is a bit less or a bit better, Impossible to predict on a mass produced, untested or quality checked (apart from I suspect, does it turn on) product. There are also two versions. Some will scramble, and others won't. No way to tell from outside as far as I can see, but I'd bet this is also why some refuse to turn on Vox, or have different noises!
Freddie
Post by Freddie »
There's definitely 2+ 888s versions. My early pair came in 2 separate boxes, with a mains charger and decent belt clip. I got another pair recently - crammed into one box, with USB chargers and flimsy all-plastic clips. They've also got rid of the 1750Hz repeater tone, so it must be a new firmware release as well.
Paul, if it's the same BF999s as I've just found on eBay, they've been around for a year or so as BF-R5 as well
Bogget
Post by Bogget »
I still have my 888,s 9 years after buying,.......the battries are still ok and radios still work perfectly.
what a great buy it was.
Bogget
Amateur does not have a CH its pronounced "am-a-tore" NOT am-a-chure !
Cymro
Post by Cymro »
Hi Bogget, I bought one of these radios years ago after reading your excellent review. Everything is still working great; the radio, battery and the charger. A great radio indeed!
