Scottish codeplug required.
gmham
Post by gmham » 04 Sep 2017, 20:19
Anyone fancy doing me a codeplug for a few freqs off interest I have for my newly purchased Retevis rt3 TYT ( md380 clone) basically looking for the uhf Scottish amateur radio codeplug plus 8ch 446 digital / 446 digital and a few other spot freqs shop watch etc ( have the required dmr info)
Cheers.
John
Would be very much appreciated.
.... Icom IC7300 / Cobra 148gtldx Mk2 / Kenwood TR751e 2mtr ssb... Ameritron ALS-600X SS HF Linear.... Cushcraft R6000 HF vertical / 80-10 mtr ocf dipole....... Astatic 575m6 mic / Heil ICM mic.
108-TM-154 - John
mr_h4ck3rm4n
Call Sign: MM6SGZ
Re: Scottish codeplug required.
Post by mr_h4ck3rm4n » 05 Sep 2017, 13:14
hi john, there is a good generic codeplug on the gb7dd site, 446 , dmr 446, and local repeaters on, just needs tweeking for gb7tt ect
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
gmham
Post by gmham » 05 Sep 2017, 14:25
108-TM-154 - John
mr_h4ck3rm4n
Call Sign: MM6SGZ
Post by mr_h4ck3rm4n » 05 Sep 2017, 18:33
HF
VHF/UHF
Antenna
Data Interface
QRZ.COM
gmham
Post by gmham » 05 Sep 2017, 20:35
Okay cheers will have a look and that's got the 446mhz channels on as well yep?
One thing when entering the TG details for instance my local shop watch uses a TG off 58 and one uses 16777215 where in the codeplug Editor software would you enter these details particular numbers ? Is this the group list entry panel ? if so it only has group list 1 or group list 2 from the drop down list ?
108-TM-154 - John
gmham
Post by gmham » 06 Sep 2017, 05:02
Added to the above can someone point me in the right direction to the most up to date alternative firmware I can load on my RT3 to give both promiscuous mode and to show list off dmr ID plus amateur radio callsign ?
108-TM-154 - John
gmham
Post by gmham » 08 Sep 2017, 10:04
Best alternative FW for non GPS md380 ? Link?
108-TM-154 - John
scottyboy
Post by scottyboy » 09 Sep 2017, 17:09
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
gmham
Post by gmham » 11 Sep 2017, 18:42
Thanks mate all done !!
108-TM-154 - John
