SDR Sharp software problem
Gemini4
Post by Gemini4 » 30 Aug 2017, 21:26
When I start sdr sharp up, it seems to big for the screen and I have no side bars..and can't see the bottom of the screen.
any clues as to whats doing this?.
grafter
Re: SDR Sharp software problem
Post by grafter » 31 Aug 2017, 21:47
Remove these lines
<add key="windowState" value="n" />
<add key="windowPosition" value="nnn,n" />
<add key="windowSize" value="nnn,nnn" />
from the sdrsharp.exe.config file and then start the programme, it should rewrite the values with defaults.
Gemini4
Post by Gemini4 » 03 Sep 2017, 10:30
Thanks Grafter ;)
Hermione
Post by Hermione » 14 Sep 2017, 10:40
When I installed SDR Sharp software I was getting the similar problem then opted the same solution provided above and it worked fine for me.
Gemini4
Post by Gemini4 » 01 Oct 2017, 12:27
