kenwood TK3101
kenwood TK3101
Hi guys. Getting my hands on these kenwoods. Can I use wouxun program cable to program the kenwood to change the frequency and if so, where can I get the program.
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
Re: kenwood TK3101
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
- radiogaga
- Call Sign: 26TM399
Re: kenwood TK3101
I use my Beofeng so if that's the same as a Wouxun then yes
30TM399 Northern Costa Blanca
Re: kenwood TK3101
Hi radiogaga does your Beofeng have the two pins or just the one pin
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
Re: kenwood TK3101
its ok guys I got the answer, I just need the software now If anyone can help please
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
Re: kenwood TK3101
Try that handyguy but you need a slow processor pc , I use an old win 95 laptop brick to program mine mate.
https://www.dropbox.com/s/v1wjrvuywmoo7 ... 1.zip?dl=0
- rooth
Re: kenwood TK3101
Software Kenwood TK3101 no need DOS , run to Windows !!!
Interface KPG22 serial .
Re: kenwood TK3101
Not seen this version before thanks rooth
- 310den
Re: kenwood TK3101
Some questions for you rooth:rooth wrote:Software Kenwood TK3101 no need DOS , run to Windows !!!
What windows did you test on?
Does it have to be a serial port or will a USB lead or USB to serial adaptor work?
Does the radio have to be in tone mode? :
That quote from your post in Computer software section.-Press and hold PTT and MONITOR Key (button under PTT) then switch ON the radio
-Continue to hold both buttons until the LED lights orange then release
-Press the MONITOR button the orange LED changes to RED and a beep sounds.
-Radio is now in tone setup mode !
I have tried so far on windows 10 64 bit and get errors or not reading all channels using a USB to serial adaptor. I can try other options as have other older laptops.
Thanks.
- rooth
Re: kenwood TK3101
Hello ! I used the serial interface with XP.
You have to enter programming mode :
- 310den
Re: kenwood TK3101
OK I did try that but it did not work, maybe because on windows 10 64 bit. I will try it on my laptop with XP.rooth wrote:Hello ! I used the serial interface with XP.
I suppose it is best to put radio in progamming mode first before plugging the lead in? If not you don't hear the beep.
- rooth
Re: kenwood TK3101
You need to programing mode
Windows 10... not work
- 310den
Re: kenwood TK3101
Thank you, will try the other laptop.rooth wrote:You need to programing mode
