*****TAKE A LOOK**** Here is my first antenna for SDR, dual band dipole build
SDR_learning
Post by SDR_learning »
HI all, first post here,
Just wanted to upload pictures of my first antenna i made for SDR, its tuned to the pbr bands.
Was made with:
a Portable site light,
2 mop handles
plastic bottle to enable the mop handles to wedge onto the site lamp, also actiing as a protection from short circuit
Choc-o-block with some sky coax core to connect the block to the dipole
and a scrap bit of wood so i can wedge it in my attic.
Cable was the stock one from the sdr unit (nooelec nesdr smart) chopped from the base end
rubber end caps where recycled from the stand of the site light
this was a freebee knock up for internal use only.
I scraped the paint off the mop handle where the cable connects to the mop and sellotaped it in place, ( I know screws with propper terminals woudl work better, but remember the site lamp is also metal and i cannot screw into the end of the antenna
SWR not known because i dont have a swr metre.
Works 100 times better than the stock SDR antenna in the bands in intent to use them on, the stock antenna are poor for my use
Bandwidth should be nice and wide due to the thickness of the mop handles
No slating me i know what a balun is, this is why i never made a off centre dipole and made the cuts as close to the mm as possible
Not bad for a first attempt,
Hope you enjoyed looking at my first dipole, :D
Re: *****TAKE A LOOK**** Here is my first antenna for SDR, dual band dipole build
Post by Admiral »
Probably my eyes and camera angle, but if the poles aren't cut in the middle then you have a dead short from radiator to ground.
Post by ch25 »
Interesting way connecting copper wire to aluminium pipe. Gz,
thedeerhunter270
Post by thedeerhunter270 »
Admiral wrote:you have a dead short from radiator to ground.
I fear you may be right.
stanogs68
Post by stanogs68 »
is that sellotape :?
love your familly
stanogs68
Post by stanogs68 »
and a snapped piece of roof baton :? :?
love your familly
SDR_learning
Sorry for not showing the other side, but this is the light base i used to make the Di-pole from. ITs kind of a H shape whereby the poles attached to the ends of the legs from the base. This is also the reason i never bolted terminals onto the poles, because the light base is metal, ( Dont worry i used a plastic bottle to fill the void space and also insulate the pole form the H base, ( Just in case)
LeakyFeeder
Post by LeakyFeeder »
U want bandwidth then u need folded dipoles.
Post by Admiral »
Ah, I get a whiff of wind-up here.
SDR_learning
It works, it was free, and its perfect for spyserver, cant go wrong. No need for anything better as my house location is in a basin with terrain all higher around me, so it works, :P
Farty
Post by Farty »
I get the whiff of something.
MrWeetabix
Call Sign: 26TM175
Post by MrWeetabix »
"Bandwidth should be nice and wide due to the thickness of the mop handles"
.......... Can you explain your statement?
stanogs68
Post by stanogs68 »
why did you destroy a good light to make that monstrosity :?
love your familly
