@sammy
- dt307
- Call Sign: 163dt307
@sammy
dragon delta force need a schematic (mosfets)
issue owner cranked the bias pots
driver and both finals toast
regulator toast
replaced reg,driver,finals,
bias set to 3.8v on the gate ssb no audio
works fine for 5 seconds .......bam driver goes short and trips my psu (set at 10 amp)
and your thoughts m8............ (i said i will keep you busy)
regulator toast
163dt307-chris
― Albert Einstein
― Albert Einstein
- cb4ever104
Re: @sammy
Bin it ! Next !dt307 wrote:your thoughts m8
- NightProwler
- Call Sign: 163TM186
Re: @sammy
cb4ever104 wrote:Bin it ! Next !dt307 wrote:your thoughts m8
- dt307
Re: @sammy
wasnt expecting that lol
....for the listeners bias part fried ekl 369dr
163dt307-chris
― Albert Einstein
― Albert Einstein
- cb4ever104
Re: @sammy
I don't know m8 . I was hoping that someone would post maybe a mic wiring problem , or something
MOSFETs ain't my thing Chris. Nick's probably you're man .
Sammy
Sammy
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: @sammy
Sammy asks for a challenge, has instant regrets
- cb4ever104
Re: @sammy
I didn't think anyone would reply Craig ! Thought you'd all be away on holidayMrWeetabix wrote:Sammy asks for a challenge, has instant regrets
- Buick Mackane
- Moderator
Re: @sammy
This isn't gonna give sammy the fix he so desperately needs, We need a uniden SSB rig that has been heavily screwdrivered with an unusual serial number
- MrWeetabix
- Admin
Re: @sammy
If I had some money to burn on eBlag I'd buy one and put him through his paces!
- Admiral
- Call Sign: 26TM157
Re: @sammy
http://www.cbtricks.com/radios/rflimite ... in_sch.pdfdt307 wrote:dragon delta force need a schematic (mosfets)
- JollyRoger
Re: @sammy
That diagram is for the transistor version 2SC1969
Regards JR
"Those who say it cannot be done shouldn't interrupt the people doing it"
- dt307
Re: @sammy
its ok the ekl 369 dr is smoked i will make one when i get a chance or just change it to the more normal zener system
163dt307-chris
― Albert Einstein
― Albert Einstein
- Snake Plissken
Re: @sammy
LOL I might just have something to interest him here....Buick Mackane wrote:This isn't gonna give sammy the fix he so desperately needs, We need a uniden SSB rig that has been heavily screwdrivered with an unusual serial number
A Taiwan R.O.C. Uniden Grant (PC-409 AC) AM/SSB....I've had this some years now, was pretty much DOA when I received it....but it's CLEAN, and I don't think anyone's ever been inside....I'd really like to get this one sorted....
Carries the serial number 83000018.......
18th Uniden Grant produced? I guess so!
Didn't TX or RX for toffee when I got it (barely switched on IIRC, I've had it a few years now stashed away)....
D37 and D38 were found to be bad, these have been replaced, and it's now fine on AM, TX and RX....shows decent modulation...
But in the SSB modes it will only transmit a dead carrier, around 10w in both USB and LSB modes....mic gain up or down makes no difference...
Finished changing all the electrolytics a few days ago, 2 or 3 were giving some strange readings...haven't checked or changed any of the tantalum's yet..
Before the re-cap, I seem to remember I was unable to align the local oscillators, I'll need to plug it back in and try again...maybe this is the area the problem lies in...
Not too familiar with these radios, more used to the intestines of 148 GTL-DX's and 360's
Anyone have any ideas? Is DC getting in somewhere it shouldn't? Or is it a balanced modulator problem or an issue with the output stage?
It's a juicy one this
Dan
Unidens (one or two)..
Cybernets (a few more)..
Stalker ST-9F DX Colonel FR360 Stag 357 Midland 79-900 Zodiac Tokyo Pegasus III Transceiver MkV
Cheiza CB702 workshop monitor
A few more, I forget...
Snake Plissken - Rescuing Presidents since a 1981 version of 1997
- cb4ever104
Re: @sammy
Well , it was the 18th one of the production line in 1978 Dan . Don't know if they made them in 77 . But if they did then yours is probably the 1000017th one off the lineSnake Plissken wrote:Carries the serial number 83000018.......
Now I'll get back to reading the rest of your post
Sammy
- cb4ever104
Re: @sammy
Well Dan . I don't have the diagram here , but I'm pretty sure the pcb is the same as the old Madison , Washington etc (MB8719) . If it was me I'd just work my way through the service manual m8 . I'd definitely start with the local oscillator/PLL section first , before doing anything else .
Sammy
Sammy
