Aha, I see you've managed to slip away from your helper for 5 minutes.26TM5890 wrote:Oh dear what a knowledge... Sure you are going to drive 400 watts on a thin wire in the loft..
Wire inverted V materials ?
- Admiral
- Call Sign: 26TM157
Re: Wire inverted V materials ?
- Buick Mackane
- Moderator
Iv'e got two words to say to that, Sh1te and sh1teAdmiral wrote: stick 400w up some 5amp insulated flex and you could burn your house down.
Presuming your talking about mains (240 volt) 5 amp flex that could handle in excess of one kilowatt
- Call Sign: M0
Explain how Antron 99, Sirio Gainmaster, DV27, Firestick etc. etc. etc. work then, they've all got a whopping big lump of insulation around the radiating element.ch25 wrote:Millions of flies eat $hit, it does not mean it is correct.
- Call Sign: Lemmy
It is thread about wire antennas mate. I do not have time or will to educate you about antenna design and performance since it is very well covered by plenty of books available to read if you willing to. Most of CB antennas are built against any science and I do not want to waste my time to analyse that curiosity.
Want know more I suggest reading Rothammel antenna book, Low band Dxing and so on.
You will be amazed how little things can make a huge change in your antenna system.
- nordhavn
Which swg wire would you recommend..... 18 or 17 swg?
- Buick Mackane
- Moderator
The thicker the better, Improves bandwidth.nordhavn wrote:Which swg wire would you recommend..... 18 or 17 swg?
- Sam P
- Call Sign: 26DR340
Kaliphan wrote:Explain how Antron 99, Sirio Gainmaster, DV27, Firestick etc. etc. etc. work then, they've all got a whopping big lump of insulation around the radiating element.ch25 wrote:Millions of flies eat $hit, it does not mean it is correct.
You're quite right, me ole fruit, aerials like the gainmaster are wire antennas...
The aerial wire of a sloping vee is already surrounded by an effective insulator (air) adding another will have no noticeable impact. In fact it should help with an external antenna as it will slow down oxidisation and keep the wire in good condition.
Ubique Loquimur
Blimey, I think I'll do one leg with the insulator on and one with it off, just to be safe !
- nordhavn
Would this stuff be any good ? 292071609442 seems reasonable priced .
Plastic or rubber insulation does have a loading effect on wire dipoles. I once made an inverted V from 3mm diameter mains cable and had to trim about 50mm of each side to get the SWR down.
A great antenna for DX - cheap as chips.
- prettypolly
- Call Sign: 26FB185
lower the swg the thicker it is
- Call Sign: M0
Yeah, about 3%-5% difference in length due to velocity factor changes but nothing else.JB wrote:Plastic or rubber insulation does have a loading effect on wire dipoles. I once made an inverted V from 3mm diameter mains cable and had to trim about 50mm of each side to get the SWR down.
- New User
- Call Sign: 2e1mpc
Leaving the insulation on the wire just alters the resonant lenth. Thatsxall
