GB7DE - DMR & DSTAR & FUSION !!!
BK
Post by BK » 21 Jun 2017, 18:06
I've been away from amateur radio for a bit, but just noticed that Allister has set up a 2m DV repeater in Edinburgh (same site as GB7EE) that does DMR and DSTAR and Fusion. How has he done that? My best guess is that he's hacked a Fusion repeater to do the other two modes, but if anyone knows I'd be interested to hear the answer.
Re: GB7DE - DMR & DSTAR & FUSION !!!
Post by Admiral » 21 Jun 2017, 18:22
Probably a DMR repeater with D-Star and Fusion gateways/bridges on reflectors on the BrandMeister system.
BK
Post by BK » 21 Jun 2017, 18:40
Admiral wrote:Probably a DMR repeater with D-Star and Fusion gateways/bridges on reflectors on the BrandMeister system.
It's listed on ukrepeater.net as being a DMR/DSTAR/Fusion repeater, I wouldn't have thought they'd do that if it was just a DMR repeater connected by gateway to the other two networks.
kilimax
Call Sign: GM0BRJ
Post by kilimax » 21 Jun 2017, 18:55
I think it's one of those multi protocol gateway reflectors.
http://dvscotland.net/
Kilimax - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Post by Admiral » 21 Jun 2017, 19:29
Must be some kind of repeater voodoo then.
BK
Post by BK » 25 Jun 2017, 12:25
kilimax wrote:I think it's one of those multi protocol gateway reflectors.
Looking at the 'equipment' section of the repeater's own website, it says they're using a ID-RP2000V D-STAR repeater http://dvscotland.net/gb7deequipment.html
So yes, it's just a single mode repeater into a multi protocol gateway reflector.
And yet the ukrepeater website says
This is a multi-mode DIGITAL VOICE repeater
This Digital Repeater has DMR capability cc:1 Connectivity: BRANDMEISTER
This Digital Repeater has D-STAR capability.
This Digital Repeater has C4FM/FUSION capability.
https://www.ukrepeater.net/my_repeater. ... sign=gb7de
The fact that they're giving a colour code for DMR suggests that it's a DMR repeater. Thoroughly confused by this.
26TM5890
Post by 26TM5890 » 25 Jun 2017, 23:44
why not drop them an email http://dvscotland.net/contact.html instead guessing :?:
Allister
Call Sign: GM7RYR
Post by Allister » 26 Jun 2017, 00:40
Morning ,
Who ever sent the email , thanks . I don’t usually look at this board regularly , only when I need some info or am trying to flog some junk off !
Anyway thanks for the interest in GB7DE the Edinburgh VHF Multimode Digital repeater.
At the moment the repeater is working on the original Icom RP2000V VHF RF Deck and the RP2C controller. It is actually controlled by a raspberry Pi running in to the Scottish D-Star reflector system .
For a while we were experimenting with a multimode that would sense the incoming transmission type and re transmit ( repeat ) on the same mode.
So if you transmit in to the repeater on D-Star you came out on D-Star , in on fusion ( DMR for amateurs !) and out on fusion, in on DMR and out on DMR it also worked on P25
The radio magic worked on a Tait Slimline TB 7000 VHF repeater controlled by a MMDVM version 1.1 modem running on an Arduno Due board. More info here (http://www.gb7dd.co.uk/home-brew/mmdvm/
There was no connection to any gateways or reflectors other than the D-Star network and that was quite problematic trying to get it working properly from a remote location rather than on site.
The issue was that the repeater was installed on an ad hoc when the Icom kit was not working properly and was probably in breach of the Notice of Licence variation documents even though no one used the other modes until after it was licensed ( Phew ! ) , so we re designated it as a multimode to keep it with in the regulations . It does not have to have all the modes available all the time, but it CAN have the modes available when its operating if we feel like it .
The medium term plan is to re institute the multimode repeater on VHF , enabled for D-Star and connected to the D-Star network defaulting to the DCS600A Scottish reflector, DMR connected to the DMR - MARC network rather than Brandmeister as the UHF repeater is on BM and MARC offers another range of connectivity options . The dual band DMR hand helds are out now as well so that helps make VHF DMR viable and one les radio to carry ! Fusion will be stand alone at this time till we see what the data implications are of connecting to that network . P25 experimenters that have VHF radio’s please get in touch , we have a special job for you !
The FM analogue repeater GB3ED is working well on another Tait Slim line repeater but the antenna’s are really shot after 40 years on the roof with coax thats full of water . When we sort that out it will hopefully become a dual mode Fusion / Analog box probably linked to an IRLP network using GM1PLY's node
Hope that helps to let folk know whats going on .
Its an interesting time to be a digital radio amateur !
regards Allister
BK
Post by BK » 26 Jun 2017, 11:38
Ah, that explains the apparent discrepancy between the dvscotland.net website and the ukrepeater.net website, thanks Allister. It was the launch of the new TYT dual-band DMR HT that got me looking around for 2m DMR repeaters, an interesting time indeed to be a digital radio amateur.
Allister
Call Sign: GM7RYR
Post by Allister » 26 Jun 2017, 12:41
Afternoon ,
It seems as if there are more amateur radio repeaters that amateurs that operate them some times !
The dual band handles for DMR seem to be creating some interest , they will certainly make one less radio to carry and offer more extensive "scanning/ Listening" facilities than the amateur offerings.
We think there may be increased use on VHF if the DE repeater offered other modes in addition to D-Star but we won't know till we try it !
Regards Allister
kilimax
Call Sign: GM0BRJ
Post by kilimax » 26 Jun 2017, 12:47
Allister wrote:Afternoon ,
Regards Allister
DE is a reasonable signal with me but currently, I only have C4FM available as Dual band. I have DMR on 70cms though and am interested in the TYT Dual band handie too. I would however prefer a mobile version with a bit more power output. Supposedly coming but like many of these announcements, pictures of something and the real deal are proving to be very very different!
Kilimax - Drew
Allister
Call Sign: GM7RYR
Post by Allister » 27 Jun 2017, 23:35
We are waiting to see what the TYT and retells dual band handles are like but as you say a 25 W mobile would be good too .
If you can hear DE from your location you should be able to get / work GB7EE from a high spot perhaps ?
Stay tuned for some tests of a dual mode UHF fusion repeater in the near future from the GB7DE / EE site .
Regards Allister
