Anyone help with this ?
I have just installed a new irf520 transistor. When i key up the power starts to drop as the transistor heats i mean like with in 20 seconds it goes from 15 watts to under 10 watts is that normal ?
- listner132
Re: Anyone help with this ?
What radio have you fitted the 520 in too ?
Hi it's in a amp rm 35listner132 wrote:What radio have you fitted the 520 in too ?
- 163TM847
How much power are you putting into the amp ?, It must be kept below 4w, Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
3 watts i've even tried 0.5 watts and it still does the same thing.Black Spirit wrote:How much power are you putting into the amp ?, It must be kept below 4w, Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
In transmit ?Black Spirit wrote: Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
- 163TM847
YesClassic wrote:In transmit ?Black Spirit wrote: Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
- Call Sign: 26fb806
Nick's bang on.... gate voltage is critical on mosfets, as is keeping it stable....
Alan 26FB806
Use it or lose it!!!!
Tested and the meter goes off the scale. Also when i tried the amp on a switch mode psu as soon asi keyed up it blow up. Now that has haqppened 2 times. It don't happen on the old psu which isn't a switch mode.Black Spirit wrote:YesClassic wrote:In transmit ?Black Spirit wrote: Also the Mosfet will burn up quickly if the gate voltage is too high [over 4v].
Do you have a schematic for the amplifier?
What was the original transistor - is this a "mod"?
Why an IRF520? They are notoriously unstable for RF applications above 7MHz.
I was told i could use it in this amp no problem.2E1IIP wrote:Do you have a schematic for the amplifier?
Ok thanks I will look over it, but at a glance the gate voltage should never exceed 20V as it clamped with a zenner.
So from the diagram is there anything i can change to get the gate voltage to 4 volts as black spirit recommended ?2E1IIP wrote:Ok thanks I will look over it, but at a glance the gate voltage should never exceed 20V as it clamped with a zenner.
The MOSFET Gate is tolerant to +/-20V, the gate is clamped to a maximum of 20V with the zenner diode - I am not sure why it is failing - I would try a different device - is it genuine or a Chinese import?Classic wrote:So from the diagram is there anything i can change to get the gate voltage to 4 volts as black spirit recommended ?2E1IIP wrote:Ok thanks I will look over it, but at a glance the gate voltage should never exceed 20V as it clamped with a zenner.
Also check the gate voltage with a DVM and an FM carrier not exceeding 5W, check the diodes and the zenner diode to be sure.
