arriva buses kent and medway
Re: arriva buses kent and medway
I hear this company has shut down is that right
I think I found this yesterday. 166.340. Picking it up quite well in Manston.
Hi All, thanks everyone for your help, yes i found it at 166.525 using sdr sharp with dsd+232 and a cheap R820T from Amazon
hi all, could that frequency be a national one for arriva? only i hear group calls for the wirral and liverpool area, not just kent and medway
Maybe they just have it setup wrong. i would listen but its too weak to pick up here.
166.3375 nxdn, seems to cover southend and merseyside with other areas in between
- Call Sign: 2E0LGZ
When they were installing the base set at our depot in Laird st on the wirral i asked the guy what the frequency was and he said it was 167 MHZ but wouldnt give the actual frequency and yes its the kenwood nexedge network
Whistler TRX-2
Realistic pro 2006
Various ham radios
MB6IGZ multi DV Gateway on 433.63750 MHZ
Realistic pro 2006
Various ham radios
Hi, yes as u no doubt aware nxdn all digital only capable listening on a new digital scanner or a cheap sdr dongle with some free software from internet, as well as 166.3375 im picking up liverpool, birkenhead areas on 166.54375,165.8375, and speke depot on 165.83125
- Call Sign: 2E0LGZ
Yep i'm eagerly awaiting the nexedge update from uniden.....if ever !
Whistler TRX-2
Realistic pro 2006
Various ham radios
Realistic pro 2006
Various ham radios
- Metradio
- Call Sign: G7HID
You might have a long wait, only AOR and Whistler have NXDN at the moment..
Mike
Mike
