So by adding a few radials, on the ground plane side of the plug, 2 inches above the massive sheet metal ground plane, it's supposed to do what?
The only thin this has done is lengthen the radiating element by a inch below the coil.
Groundplane Radials Kit's for mobile aerials
- Yeti
Re: Groundplane Radials Kit's for mobile aerials
- Mudslinger
About as much use as SWR grease.
- Ashtec
- Call Sign: M6LTD
Are well it look's good if note else still my work better on the land rover
- Mudslinger
Somewhere for the birds to perch if nothing else.
- Ashtec
- Call Sign: M6LTD
- 21kpi015
- New User
- Call Sign: 21KPI015
Where have u buy this radialkit
21 KPI 015
Sweden Coordinator
Sweden Coordinator
Noooooo..... don't do it!
