New to CB advice
New to CB advice
New Year New Project.
I have just gotten my first 10/11/12 meter radio,
So I can work UK CB and 10 Meter ham radio but I am lots to know which is the best antenna, for a small garden come back yard.
the antenna I am looking at are listed below. and I an open to other that are about that same. due to space being about 1 x1 Meters
NEW Sirio Vector 4000 @ £104 Frequency 26-29MHz
Sirio 827 @ £109 Frequency 26-29MHz
Sirio New Tornado 27 @ £70 Frequency 27-30MHz
I would like it to cover UK CB and 10 Meters. due to some friends being on CB,
I would be grateful for any help advice and tips when it comes to CB
Thank You
Radio Ryan
(Sorry if this was the wrong feed for this post, Admin feel free to move to right feed please)
Thank You
Radio Ryan
- porky.69
Re: New to CB advice
hi ryan i use a Antron 99 for 10 and 11 meters....just plug n play
- ghost123uk
- Call Sign: 26TM953
Hi Ryan,
If so, what is surrounding this space, and how high are these surrounding objects?
As I'm sure you know, any aerial won't work very well at all unless it is in pretty much "free space".
Do you mean literally you only have a square of 1Mtr x 1Mtr to site this aerial?radio_ryan wrote: due to space being about 1 x1 Meters
Anything with legs is pretty much out then. What about a Gainmaster or Imax 2000?
- MrWeetabix
- Admin
- Call Sign: 26TM175
iMax 2000.Plug, Play, Be happy
- mof000
Wayyyyy better than the Antron!MrWeetabix wrote:iMax 2000.Plug, Play, Be happy
Is there a thread on TM1 about the antron?!
- porky.69
ive not seen onemof000 wrote:Wayyyyy better than the Antron!MrWeetabix wrote:iMax 2000.Plug, Play, Be happy
- Oggy
FFS here we go again!!.mof000 wrote:Wayyyyy better than the Antron!MrWeetabix wrote:iMax 2000.Plug, Play, Be happy
- prettypolly
- Call Sign: 26FB185
use a 36 foot x 3 delta loop
To cover CB and 10m without fooling yourself you need 2 antennas. Not wideband dummy load.
ghost123uk wrote:Hi Ryan,
Sorry for the delay. Yes that's about the size I have to pay, it an old house with a back yard, if I go over a meter I will be over hanging next door,
I have to go upwards
- ghost123uk
Even so, a back yard that measures just over 3 feet long and 3 feet wide is a VERY small back yardradio_ryan wrote:Sorry for the delay. Yes that's about the size I have to pay, it an old house with a back yard, if I go over a meter I will be over hanging next door,ghost123uk wrote:Hi Ryan,Do you mean literally you only have a square of 1Mtr x 1Mtr to site this aerial?radio_ryan wrote: due to space being about 1 x1 Meters
Depending on what is surrounding whatever space you have (ie other buildings etc) and how close they are to this small square of space, a simple 1/2 wave "Silver Rod" type aerial (no ground-planes to worry about) might be one answer. It would benefit hugely from being mounted as high up as you can, on a scaffolding pole for example.
it looking that ways, due to trees, in our garden and next door, and how the houses where built back them,The Collector wrote:Anything with legs is pretty much out then. What about a Gainmaster or Imax 2000?
it also rules a beam out, unless it goes sideways and is fix, but it would be beam at the house, unless it was just to waves poles of no more than say 2 meters running across the shed and cole bunker. but that would be fixed to.
Sorry for the dealch25 wrote:To cover CB and 10m without fooling yourself you need 2 antennas. Not wideband dummy load.
that is looking like the way to go, with a ATU, been told that I can or it possible to tune down to 20 with one.
But do not know if this is fact,
Putting one on a pump up mast may do the trick.
Thank You Ch25
- johnkyrle
- Call Sign: 26TM3375
In all fairness,I know everyone takes the **** out of the Silver Rod.But,at the end of the day,it is an end fed di-pole which you can tune to match your ground plane i.e;mounting mast.Okay it may not do the job as well as the more expensive home base antenna's but,from experience,s.w.r it once and never touch it again.Good for a small plot with no garden as such and they are as cheap as chips.I run one static mobile on a drive on plate.Park up,chuck it up and Hello DX station.The higher you can mount it,the better though being a 1/2 wave radiation.
