Antenna Problem
- spoooky
Antenna Problem
Hi Guys
Iv Been Off The Radio For A While After Moving Into A 3rd Floor Flat (council wouldnt let me put up a Antenna)
Now Iv Moved Into A Bungalow , So Its Time To Get A Radio Again
But I HAve A Problem
Im Thinking Of Getting A Diamond X50 Or Sharmans X50 ......Would There Be That Much Difference Between The Two ? ?
Also The Only High Place I Can Put it Is On A 7ft Pole On The Gable End
The Problems Is .I Have A Tree Right Next To Me And The Antenna Will Be Right In It
It's Ok Now I Suppose But When Spring Comes It Won't Be Visable Due To The Leaves
What I Want to Ask Is ... If I Dont Put It There , The Next Best Place Is On My Guttering
Which Will Be 10ft Lower But About 15ft Away From the Tree
Which Would You think Would Give Me The Better All Round Performance
26-TM-621
Re: Antenna Problem
In my world of V/UHF height trumps foliage.
- spoooky
Re: Antenna Problem
Sneak out one night with a bag of 6 inch copper nails and a pop bottle full of diesel - bray the nails in to the root and and soak liberally with diesel - 3 months later no more tree!spoooky wrote:Can't Touch It ..It's Not On My Property
- WeatherWatcher
Re: Antenna Problem
Trouble is if it falls will the damage be your side or the owners?
- spoooky
- WeatherWatcher
Re: Antenna Problem
Get a longer pole, and stick a small TV antenna on it below the other antenna, the co-ax from the TV one does not need to be connected unless you also get crap TV reception as well.
- Buick Mackane
Re: Antenna Problem
murder your neighbour then and bury him/her under the tree, jobs a good unspoooky wrote:Its In A Communial Garden
so Murdering It Is Out
Re: Antenna Problem
Foliage is not a major issue, most repeater jammers in the 70's and 80's were mounted up a tree.
- Auldgeek
- Call Sign: GM0BRJ
Re: Antenna Problem
Trouble with that is it will just add extra nutrition into the soil and the tree will grow even higher.PLL02A wrote:murder your neighbour then and bury him/her under the tree, jobs a good unspoooky wrote:Its In A Communial Garden
- Call Sign: 26CT2116
Re: Antenna Problem
Or get a mag loop - height not an issue if vertically polarised. They are expensive and QRP rated at no more than 30w PEP. But an option? look at Alex loops alpha loops or chameleon loops. MFJ ones are mightily expensive and have some build issues, but are used as permanent home set ups as they can be tuned remotely.
One big thing about them is that you need to retune if you only move slightly within the same band. But they give you lower noise typically than a vertical.
Check out eham reviews to see what people say.
- Tigersaw
- Call Sign: GW6RRL
Re: Antenna Problem
As admiral said, get it up as high as possible. Mines up 45ft in an oak tree, branches all over the place but it works far better than it did when at about 30ft gable end.
Also good co-ax, I thought rg58 would be fine, changed to 213 and it really did improve.
- spoooky
Re: Antenna Problem
I'll Just Put A X50 Up I Think And Hope For The Best
And I HAve A ft-8800e Coming
So I'll Give It A Try , On The GAble And Guttering
26-TM-621
- FakeJake
- Call Sign: 2E0SEY
Re: Antenna Problem
Just remember not to cheap out on coax! Makes a huge difference on VHF/UHF
Jake 2E0SEY
Saltney, near Chester (Cheshire-Flintshire border)
Monitoring 2m simplex (when I can)
Dysgwr Cymraeg
Dysgwr Cymraeg
