New President
- AShockwav
- Call Sign: KE6LYU
Re: New President
Has anyone used the + version on CW yet?
Really like to know if that addressed the issue that all the others had.
73
Jeff
73
Jeff
Re: New President
Ask direct that's easiest way [email protected]AShockwav wrote:Has anyone used the + version on CW yet?
73
Jeff
My guess maybe, but certainly not sure at all. I've not considered using it at all on mine
73 Simon
- Call Sign: TT
Re: New President
Hi, I'm new here but this forum seems to be a good source to solve my problem :-)
Yesterday I got my brand new Lincoln II+ (xmas present to myself)
First impression is ok but but I was a bit disappointed that they have left out the 11m band, I have no plans to use it on that band but I had a plan using 27.555 as a monitor freq. to see if there is some possible activity on 10m, does anyone know if there is a mod for that ?
My second problem is that I'm not able to get the software from President to operate. I assume when connecting the radio to a Windows computer it will appear as a com port but there is nothing in my Device Manager.
I made a quick test and connected it to a linux computer and the dmsg commad show that the radio is connect but does Windows need any special comport driver ?
Lasse
Lasse
- Mudslinger
Re: New President
There is a wire loop inside the radio which you need to cut which then enables 11m
Pretty sure the L2 isnt PC programmable unlike the other radio which share similar internals. (CRE-8900, AT-6666, DR-135UK etc)
- Auldgeek
- Call Sign: GM0BRJ
Re: New President
I don't think the L2+ has the usual wire to cut but I may be wrong. I have one and I know it was modified by Knights before it left. It was not a wire as far as I understand.Mudslinger wrote:There is a wire loop inside the radio which you need to cut which then enables 11m
- Mudslinger
Re: New President
Might just be a couple of button presses then like on the Alinco DR-135.
- Call Sign: TT
Re: New President
Thanks everyone, there is no wire to cut like I have seen on other Lincoln radios.
I have attached a picture showing
Regarding the programming via PC, there is a programming software for this L2+ and the President site but I'm not able to make the communication work so I have sent a mail asking if there is any special com port driver that is neede.
Lasse
Lasse
- Call Sign: 2e0myn
Re: New President
I use the lead for the crt9900/alinco 135 on mine .the drivers can be a pain sometimes just use the latest prolific one.
- Call Sign: TT
- Call Sign: TT
Re: New President
Cable ordered :-)
But the next step now is to find out how to open it for 11m
Anyone ?
Anyone ?
Lasse
Lasse
Re: New President
Maybe the programming will do it????
- Mudslinger
Re: New President
Might be worth emailing President?
It is probably a case of pressing a couple of buttons as you switch it on.
- Call Sign: 2e0myn
Re: New President
its a menu option to open it up and a component inside radio that's how I did mine
- Oggy
Re: New President
I'm surprised that the cat hasn't been let out the bag yet on this mod.
