UBC3500XLT Charging
UBC3500XLT Charging
Okay, so finally shifted my immaculate 3500 for half of retail price, the buyer says that it's faulty because it takes 48hrs to charge the batteries internally, now I did tell him that's a known issue with these and that he would be best buying an external charger, but he wants to return it as he doesn't want that 'faffing about', fine, no problem, I'm a nice guy, but is 48hrs for a proper charge too long for these, or is it a bit too long and the thing is struggling? I made sure the little switch behind the batteries was in the right position for rechargables and it has brand new 2650mah Energizer batteries (which have had a few charge/discharge cycles).
Re: UBC3500XLT Charging
Is that with the radio on Rx too ? If the switch is in the wrong position it won't charge ! It has been advised many times not to charge batteries using the internal charger, some radio's have had the charger circuit fail or with the higher capacity batteries take a long time to charge.I would expect it to take 14 to 16 hrs to charge 2400 mA types with the radio switched off.Admiral wrote:Okay, so finally shifted my immaculate 3500 for half of retail price, the buyer says that it's faulty because it takes 48hrs to charge the batteries internally, now I did tell him that's a known issue with these and that he would be best buying an external charger, but he wants to return it as he doesn't want that 'faffing about', fine, no problem, I'm a nice guy, but is 48hrs for a proper charge too long for these, or is it a bit too long and the thing is struggling? I made sure the little switch behind the batteries was in the right position for rechargables and it has brand new 2650mah Energizer batteries (which have had a few charge/discharge cycles).
About 14hrs to get the charge complete message on mine
2700mAh batteries in use
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Cheers for the replies, I know they're slow, and I know upgrading from the (I think) 800mAh that came with it slows it down, I always used an external charger, sounds like mine (soon to be returned) unit may be slower than most.
- stanogs68
you still didnt say what you wan for it put it on sale as faulty only kidding how much
love your familly
- Buick Mackane
A 2650 mah battery with a charge current of 800 ma should take around 4 hours to charge. So yip. Theres defo a problem somewhere.
**edit**, Thought you meant the charger was 800 ma but you meant the original batteries.
Yeah, them shítty green things, no markings on them, presume 800mAh as that's about the grottiest they make.
- stanogs68
- thelad
Mine from new came with some 2250mAh GP cells, would take a good over night charge 5pm - 9am and that would show 4.15v on the scanner, its a very slow charger that is built in and mine never say fully charged on the screen. I now charge the cells in a smart charger and ballance them so gets me around 4.20v from 2900s. The 2250 cells say on them 'standard charge 16hrs at 220mA'
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
I'm expecting it back today or tomorrow stan, so will check the serial to see if I've been robbed and make sure it's all there and intact, if everything is okay then I'll bundle in a smart charger and probably put it up for sale again next week.
I will also check the internal charge time with the supplied charger as I've never actually done it this way, I've always used an external one.
I'm looking for a VHF 380 or clone if you want to deal.
The other thing to think about.Was the radio designed to charge Ni Cads or metal hydride cells, that can affect charging times as the radio's sometimes do not detect the V point correctly.thelad wrote:Mine from new came with some 2250mAh GP cells, would take a good over night charge 5pm - 9am and that would show 4.15v on the scanner, its a very slow charger that is built in and mine never say fully charged on the screen. I now charge the cells in a smart charger and ballance them so gets me around 4.20v from 2900s. The 2250 cells say on them 'standard charge 16hrs at 220mA'
So may not display correctly.
- stanogs68
Admiral i would only probably use it a homebase 90% of the time any way as long as the AC is okAdmiral wrote:I'm expecting it back today or tomorrow stan, so will check the serial to see if I've been robbed and make sure it's all there and intact, if everything is okay then I'll bundle in a smart charger and probably put it up for sale again next week.
love your familly
The built-in charger on the 3500 was never that good, I'd just turn it off and use a separate charger.
From what I remember it's just a timed low-current trickle charger. It only charges while the radio is off and seems to cut off after a fixed time (14 hours according to the manual) regardless of the battery voltage, and the timer resets if you disconnect the power or turn the radio on before it finishes charging, It definitely had me wondering if there was something wrong until I worked it out.
