Zastone D900 DMR ?
Mad4radio
Re: Zastone D900 DMR ?
Post by Mad4radio »
Yep, a dual mode set will defo be handy to have, I have a way of linking our DMR capabilities here from VHF-UHF/UHF-VHF lol all done via the server with the added option of going out via both the DR3000's providing the sat within the same rooms as the VHF/UHF DMR radios, Works pretty well it does sometimes you could say too well lol
thelad
Post by thelad »
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Post by Admiral »
'+Baofeng USB Programming Cable '
Interesting, I might try my Bumfeng cable later to see if it works.
thelad
Post by thelad »
My Bumfeng cable was a bit iffy so may try use the one that came with the Zastone to re do my 888s.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
14FRS2679
Call Sign: 14TM1180
Post by 14FRS2679 »
Bought 2 last month great radio, be sure you re buying from the seller located in uk, cause there s actually a chinese seller, selling at the same price but expedited from china.
My baofeng cable didnt worked with the d900, so I Just used the provided cable.
Mad4radio
Post by Mad4radio »
thelad wrote:My Bumfeng cable was a bit iffy so may try use the one that came with the Zastone to re do my 888s.
what you reckon thelad???? Was It/Is It to your expectations
thelad
Post by thelad »
Got my hands on it last night and set up the firmware with the hack, not had time to do a codeplug yet or had any audio on it yet. Used the keypad to stick some DMR users in but no joy, the green LED lit and the S-bar was showing Rx but got no audio, tryed all 16cc in proximus mode with a simplex and nothing!
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
stanogs68
Post by stanogs68 »
sounds dodgy ,surely there would be something ,sure your not panicking mate
love your familly
LeakyFeeder
Post by LeakyFeeder »
Doesnt the Bumfeng cable have a chip in it....and the MD380/clones have same chip in the actual radio?
Mad4radio
Post by Mad4radio »
thelad wrote:Got my hands on it last night and set up the firmware with the hack, not had time to do a codeplug yet or had any audio on it yet. Used the keypad to stick some DMR users in but no joy, the green LED lit and the S-bar was showing Rx but got no audio, tryed all 16cc in proximus mode with a simplex and nothing!
yeah you should be hearing something!! what ever It Is your listening on I'd be making sure the details are Implemented are correct, I'm sure even for the hack to work you need at least the CC to be correct pal, I'll forward you some details where we play If you like check your Inbox there's usually 4/5 of us on most evenings & during the day on DMR simplex
silverspring
Call Sign: G7OVK
Post by silverspring »
Got mine yesterday. Works great. It's basically an MD-380 in a different chassis. Can't complain at all for £55, just a shame I'm not in the capture area of the 2 repeaters in my area, well at least not strong enough to receive on a rubber duck antenna.
Mad4radio
Post by Mad4radio »
outdoor twig mate will sort that just make sure to purchase the right adapter from radio-external antenna
f4phixeruk
Post by f4phixeruk »
Up to £90 a unit now. Wish Id got the 2 for £108
gmham
Call Sign: 108TM154
Post by gmham »
Can I take this opportunity just to wish each one off you on here a very happy Xmas !
Okay Santa brought me a nice new Zastone D900 DMR just taken it out the box and before I try and learn there is to learn on DMR just wonder if its possible to easily enter the info I have here to listen into my local shopwatch channel or do I have to do it via software ?
The info I have that was kindly supplied by a fellow TM1 member is :
453.5000
CC8
Scan slot 1
Repeater / time slot 2
Group 16776415
Anyone advise me what I need to do to enter the above into the radio if poss without the software ?
Also believe its possible to listen to analogue on this particular radio. How do I switch between digital and analogue ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
thelad
Post by thelad »
When i got mine the keypad option to program it was not selected and can only be selected via CPS, quick google will get you the software, when you have a ch programmed in you can enter CC and Slot via the keypad but not the TG. Best off via pc, have a play you cant really go wrong! Got mine working and its very good, my only gripe is the audio is hard for me to understand when i have local shopwatch on but its fine when i have the hams on it. Better with a speaker mic.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
