SE-HF360 ANTENNA ANY GOOD ???
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Would a SE-HF360 antenna be any good just to get me going on the hf bands if not what would you recommend ???
rizz
Re: SE-HF360 ANTENNA ANY GOOD ???
Post by rizz »
I wouldn't recommend a vertical for anything over 20m put up a wire dipole if you can.
Yaesu FT7900, Superstar 3900 Red Display, President Lincoln, Adonis 308, Astatic road devil, Microset 27-200T Amp. Sirio Gp-3 5/8th 2m Antenna.
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HI RIZZ what sort (length) wire dipole would you surguest
porky.69
Post by porky.69 »
what bands are you wanting to use mate ?
rocket
Call Sign: M0ROC
Post by rocket »
To answer your question, the HF360 works quite well on 10-40m at least.
A wire dipole is all well and good as long as you have the horizontal space to string one out, and not everyone can.
73 de Mark
M0ROC, 26HB896, 26TM896
M0LGC (Letchworth Garden City Amateur Radio Society)
Flightradar24 live feed: T-EGGW38 via AirNav RadarBox 3D
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HI MR PORKY,i would like a nice simple antenna to enable me to use it with the ICOM 706 MK2G i have just bought my self ,trouble is i have very little garden space so any thoughts on the subject would be a help thank you ..
sec1223
Post by sec1223 »
hf360 10-40m as stated works quite well
cant stand IGNORANT b******ds
andymuza
Post by andymuza »
You love Antenna threads Warlock LOL.
If you have room for the HF360 then you definitely have room for a Delta Loop.
See one of the your other "What Antenna do you recommend" threads as I gave advice on how to make one along with with the formula's and a link to a video.
In fact, it was this thread.
bc73
Post by bc73 »
I would add +1 for the SE-HF360, better than you would imagine.
_____________________________________
MM6BCF
108 TM 45
FT-747-GX.
IC-706-MK2G
Yaesu FT7
Stalker 9FDX
Dirland SS3900E
Nato 2000
Alinco DR135
Amstrad 901
73 and 51
Nothing's ever easy! {bnghd}
DaveP
Call Sign: 2E0DDF
Post by DaveP »
Following my enquiry in a previous post, I decided on a long wire. I have gone for a Windom type 20m through to 10m its only 10.5 meters long, split into a 2/3 x 1/3 . I got it up 25 feet on a pulley fixed to the house and the long leg at just over 7 meters is fixed to the top of an 8 meter telescopic roach pole, like wise the short leg is mounted the same way. So it is in a V shape, the first contact on 20m I got 5 and 8 into USSR with 50 watts second contact 5 and 5 into Turkey. Wondom's are cheap and can be got from Moonraker my one was just under 40.00 delivered.
73s Dave
Yeasu FT-897 wide banded, MD100 mic, Yeasu FT-857, Yeasu FT-8800r, Diamond X300 2/70, A pair of phased shunt type loops for 2/70. 6 meter shunt type loop, Windom 20m to 10m long wire, Antron 99s for 10 and 12 meters. As you can see Im a Yeasu Man and loopy to boot. :D
sec1223
Post by sec1223 »
just put mine back up today
Post by ch25 »
Any antenna is better than no antenna, but I wouldn't recommend such a junk to anyone.
