118mhz or 108mhz
acl777
118mhz or 108mhz
Post by acl777 »
I've got an Icom 2730 and wanted to play around with airband. What am I missing though as the frequency coverage starts at 118mhz as opposed to 108. A quick Google indicated voice transmissions begin at 118mhz AM. That's fine as it's only voice transmissions I'm after but I noticed some airport ATIS frequencies fall into the 108mhz to 117mhz range.
mercury888
Call Sign: M0RVB
Re: 118mhz or 108mhz
Post by mercury888 »
So it misses the whole navigation section 108 to 117.975. The manual says the same claiming airband is "118.000 MHz to 136.99166 MHz" - you don't seem to be missing any settings, the radio just starts at 118 not 108.
Probably the only thing voice-wise you miss is the ATIS stuff - sometimes handy if you have the washing out and your local airport is indeed local!
CB: President Grant II (1980's handle: Bootstrap; now 26TM868)
ADS-B: FR24 T-EGNM-63
Yaseu FT450D; Signal R535; W-SDRX1 + Gnu Radio and CubicSDR
Baofeng UV5R; TYT MD380; Trio TR-9130
acl777
Post by acl777 »
Thanks for the info.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix »
Not much below 118 for Airband, so I wouldn't worry about it fella. :-)
acl777
Post by acl777 »
Thanks.Is there an up to date website for ATIS frequencies only. I've googled around but can only find one from 2014. The others are all mixed . I have an interest in dxing ATIS transmissions from this country and the continent as they make for good VHF propagation beacons because they transmit 24/7 and from fixed location.
Call Sign: G4RMT
Post by paulears »
The bottom ten MHz 108-118 is for beacons. VOR beacons for nav - so nothing interesting down there at all, and if you do live near one, they're quite unpleasant to listen to.
