Thanks for that Sec, but its the same for me as it is for you I expect... You get a buzz out of modding these things lol.sec1223 wrote:Iv got one already converted. Drop me a pm if your interested
Although after having done a few now I've come across a few electrically noisy one's to date. Its not the end of the road for them as its possible to knock up an external filter to clean up the output of the small few that are noisy. I really must get a scope soon, and test and take some notes under varying loads.
If a supply is causing interference on HF it doesn't mean it necessarly wil on VHF or UHF. Its just that my main use is CB radio for these units, or at least testing them. As some will know electrical noise at idle outputs can be very different when medium to heavy loads are applied, output ripple noise etc. So at the moment I'm looking into external self built inductance capacitance filters. And a scope would really help.
But having said that, for the most part the majority of server supplys have a clean enough final output. Its a challenge to clean up the noisy one's.
