Help with high swr on wire diapole 11 mtrs
original45
Call Sign: 45
Re: Help with high swr on wire diapole 11 mtrs
Post by original45 »
PLL02A wrote:Heres my attempt, We'll see what happens when i hook it up :)
Looking good. Let us know how it works
Buick Mackane
Post by Buick Mackane »
will do, made the centre out of some old persplex, beats buying one on ebay for a tenner :)
Buick Mackane
used some of those crimping things on the ends, left an inch & half poking through incase any adjustments need to be made which they probably will.
original45
Call Sign: 45
Ah that looks a good idea ,I just cable ties paracord on the end of mine and then sealed end of wire with that self amalgamating tape.
I'm all for making it out of stuff lying about.
I need mine compact ,so going to look into smaller Balun if poss and go straight to coax without a s.o or pl plug .
Stuffed my s.o inside a pop bottle end with lid on to keep potential water out .
