superstar 3600??
- BaDBoY1985
- Call Sign: 223TM085
superstar 3600??
any bodi know somthing abought this rig???? INTRESTING IT HAS ALINGNMET problems
RANGER 69FFB4 I SIRIO GPE 27
sorry for the writing i am HUNGARYAN
- BaDBoY1985
Re: superstar 3600??
old or new version
- Mudslinger
They are very similar to the Superstar 3900's, only with less channels.
That one looks like it has a couple of add-on boards, possibly a UK40 Eprom and a bleep board?
What is the board number? It is usually near the front on the solder side.
- 14CS06
- BaDBoY1985
claude i dont kow if its a new or old version of the 3600? and normaly how is the radio if it worcks 100%
- cb4ever104
Actually they're exactly like the 3900 . Just another clone . It'll either have a 6 way band switch (not all marked) , or 3 bands on either the HI and LOW tone switch .Mudslinger wrote:They are very similar to the Superstar 3900's, only with less channels.
Yours is TAIWAN , so it's old . As Claude says an EPT360011 pcb . The newer ones are all 14Bs ( I think) . I've sold a couple in the last year .
Sammy
- Dragonfly
- Call Sign: 26TM363
The later Superstars need 20 mins warm up to get on frequency then Alignment appears to be the same as the 3900 . http://www.cbtricks.com/pub/secret_cb/r ... erstar.htm
- astradyne
In the case of the 3900's the older the better. I'm not sure if the 3600 pre dates the 3900's slightly?
- BaDBoY1985
thank you all for the quck replys were helpful
- 13EL121
- Call Sign: 13DA121
Superstar 3600 with SRT-3600-10 board. Don't know if it is old or new version. Looking for the correct value of xtal X2. See other post here in the 10/11m repair section...
- cb4ever104
Apologies for what I said about these radios. Just shows what can happen when you don't know what you're talking about . The 3600 with the R.BEEP marked on the CH9 switch are 6 band 3900 clones , but these ones seem to be based on the single crystal EPT360011Z pcb which makes them a bit different. That's what I love about this hobby. Just when you've thought you've seen it all ....cb4ever104 wrote: ↑31 Jan 2016, 18:29Actually they're exactly like the 3900 . Just another clone . It'll either have a 6 way band switch (not all marked) , or 3 bands on either the HI and LOW tone switch .Mudslinger wrote:They are very similar to the Superstar 3900's, only with less channels.
Sammy
- 14CS06
- cb4ever104
Yeah . I know that now Claude . Pity we don't have a proper schematic for the 10Z .
Just from what I've picked up over the last 24 hours . There's a sticker on the back of the Taiwan radios saying either "LO BAND" , or "HI BAND" . The LO BAND version is this "SRT 3600-10" pcb . I haven't seen the inside of the HI BAND one yet . It might be this same SRT 3600-10 pcb with both crystals fitted . Or it might be a later 6 band EPT board like the 13B , or similar . I'm going to add these 2 radios to my list .
- 14CS06
- cb4ever104
Hi Claude.
I think we've already had this conversion a few years ago when we discussed the Franklin. This diagram isn't correct. The diode matrix numbers are wrong. Anyway , it's not a major issue.
Thanks anyway.
Sammy
Thanks anyway.
Sammy
