Alinco DR135 Software
andymuza
Re: Alinco DR135 Software
Post by andymuza » 10 Dec 2014, 13:05
Switch the radio back to band 1 and try again
andymuza
Post by andymuza » 10 Dec 2014, 13:06
And what happens when you try to reset?
mickymcd
Post by mickymcd » 10 Dec 2014, 13:27
The radio just stays on 28mhz when I hold the fund function and ew button to choose band 1 or band 2 as when I got it its doesn't have those options now it displays en 1 :oops:
andymuza
Post by andymuza » 10 Dec 2014, 13:36
If the software is still communicating with the radio goto setup and initial settings and write that to the radio. If it says it's in the wrong band mode change the band mode on the software and try again.
If that fails disconnect the radio from the USB and power cables. Reconnect the power cable and try to reset again.
If that still doesn't work, close the software and reconnect the USB cable and restart the software and try the above again.
Road_Hog
Banned
Banned
Post by Road_Hog » 10 Dec 2014, 14:28
mickymcd wrote::oops: YEP I JUMPED STRAIGHT IN ! arghhh it wont reset back to how I got it the dat file I have is ok few people I know of are using it the radio was in 11m mode when I programed it all I get at the mo when connecting radio to pc is frequency band is wrong and all I got it 28mhz everywhere on radio :oops:
Have you tried uploading the Dat file attached in my post?
mickymcd
Post by mickymcd » 10 Dec 2014, 15:36
Managed to get it back somewhere went back over my tracks I hadn't pressed the function key long enough for it to change to band 2 a quick press wasn't enough :oops: ill try later on loading the dat file a mate has sent me I thought it had already saved to radio but not :roll:
m0awn
Post by m0awn » 10 Dec 2014, 17:22
Does anyone know if there is any MAC software for this radio ?
The nearest I can find is CHIRP for the DR135T ( not a lot of cop I suspect on the DR135DX )
I've emailed the developers at CHIRP ,fingers crossed {bnghd} {bnghd} {bnghd}
Triple3
Post by Triple3 » 10 Dec 2014, 17:58
I got stuck recently with a "just reads 28mhz everywhere" programming fault.
In the end I had to "read from radio" then send "write to radio" the .dat file of your choice after you have enabled band 2.
mickymcd
Post by mickymcd » 10 Dec 2014, 21:50
Thought id try again only thing I done different this time was to put radio in band 2 mode 11m although this was already done as I only use the radio in 11m :crazy: anyway pluged cable in fired sware up read channel data saved it off written file lad I know emailed me works ok no problems :wave:
Triple3
Post by Triple3 » 11 Dec 2014, 08:11
Pleased you got it sorted in the end :thumbup:
It seems like the radio does not like new dat files being sent without reading the existing dat file first :crazy:
bigyun2000
Call Sign: M0MTD
Post by bigyun2000 » 08 Mar 2015, 17:32
Hi all
I have just purchased the ALINCO DR-135DX and was wondering if anyone had a pre-programmed DAT file for UK 40 etc etc.
Tony ex RAF Gulf War Vet 1990/91
ICOM IC-7410 | ICOM IC-5100 DSTAR | Alinco DR-135DX |
Western HF 10 | Diamond X-200 | SIRIO Gain Master | SIRIO 5000 |
PlanePlotter | ShipPlotter |
WinDX
Call Sign: 26TM1500
Post by WinDX » 08 Mar 2015, 17:35
It's the CRE 8900 software you need, put a search online, download it and then you can programme the channels you want.
bigyun2000
Call Sign: M0MTD
Post by bigyun2000 » 08 Mar 2015, 17:38
Thanks found it i just gotta wait for the radio to come. Anyone know the difference between the Alinco DR135DX & Alinco 135UK?
Road_Hog
Banned
Banned
Post by Road_Hog » 08 Mar 2015, 17:58
bigyun2000 wrote:Thanks found it i just gotta wait for the radio to come. Anyone know the difference between the Alinco DR135DX & Alinco 135UK?
Yes, see the same question you asked in the other post.
WinDX
Call Sign: 26TM1500
Post by WinDX » 08 Mar 2015, 21:22
The UK is the 'UK' version, the DX is the older European model.
