hi all not sure if this is right place to post this,
i just got myself one theses
http://www.ebay.co.uk/itm/RTL2832U-News ... 1574214246?
does anyone no were i get the good free easy to use programme to decode them all for me so i can listen in
Help Needed
Help Needed
RNLI is a Charity that saves lives at sea, www.rnli.org.uk
- Call Sign: RDX64
Re: Help Needed
All it says is:
Replace the poxy little antenna with an external one.
They also work on Android things - like a tablet etc.
If it's meant to be the SDR dongles then yes, I have one as have many on here.This listing (RTL2832U-News) has been removed, or this item isn't available.
- andymuza
Re: Help Needed
Have a look HERE.
Re: Help Needed
hi what sort of antenna do you have now with the dongle ?
Re: Help Needed
i notice there are like different software from diffrent links, what best one also easy one to use, im new to mototrbo
- Black_Pirate
- Call Sign: 26TM034
Re: Help Needed
search Facebook for "RTL" or SDR.....
there's a great page on there.....
lots of help......and help files and examples
for you there....
for you there....
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... See FB page...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
