HF portable imaging problems.
acl777
Post by acl777 »
Unless somebody can advise otherwise I'm getting imaging on my Tecsun 880. I'm currently receiving Radio Romania on 28.020. Is there anything out there that doesn't produce images in a portable price range.
acl777
Re: HF portable imaging problems.
Post by acl777 »
Seems like quite a few images around there. Switching from dx to local seems to cure the issue. I'm only using the wire supplied with the 880, nothing active.
DutchKiwi
Call Sign: 41AC101
Post by DutchKiwi »
If you want some response regarding your Tecsun PL-880, then I would recommend you to go to this website:
http://swling.com/blog/2013/12/a-review ... ave-radio/
There is a extensive review about this radio, and there are many comments below; including comments about imaging.
Good Luck.
Keep CB radio alive !
41RC101 - (I use this callsign also on zello)
41AC101
acl777
Post by acl777 »
Thanks for the link.
