Pic Programmer
- Dragonfly
- Call Sign: 26TM363
Pic Programmer
The son purchased me a RaspberryPi mini computer and I came across this design for a Pic programmer so im having a go a building one , its abought half built in this pic I took last night ,
- Dragonfly
Re: Pic Programmer
Never heard of these RaspberryPi things till my son landed home with two , His is the red top of the range and mine is the standard one .
- kr0ne
Re: Pic Programmer
Nice!
Have you played around with the GPIO pins on the Pi yet? If you install the wiringPi library you can even read them and flick them hi/lo from a bash script or the command line!
*loads* of fun to be had thataway.... just be careful with them as they are apparently directly connected to the core of the CPU - so no grabbing hold of them while moonwalking around the carpet!
- Dragonfly
Re: Pic Programmer
Cheers for the tip . Only had this Raspberry a few days so far and been working but im off Monday Tuesday so will have a decent play with it .
- Admiral
- Call Sign: 26TM157
Re: Pic Programmer
I've got one in a drawer somewhere.
Got it for an XBMC rig, sadly the 'HDMI' isn't 1080, nearer to 640x480.
Might get it out again one day and hook up an RTL.
- kr0ne
Re: Pic Programmer
I played around using one as a remote ethernet head for an RTL dongle using rtl-tcp component of the Osmocom package. Even wrote a simple shell script to monitor any frequency changes and switch some front end filters in and out using the GPIO.Admiral wrote:I've got one in a drawer somewhere.
I gave up on this approach in the end though as i found that I couldn't reliably get the bandwidth I wanted. I always suspected that this was because the ethernet port on the Pi is actually connected through the built in hub attached to the Pi's single USB port...
- Dragonfly
Re: Pic Programmer
Here is the Plan im working from , And few other interesting projects on this page . http://www.techmeology.co.uk/rpipic/
Here is a programmer without the diagnostic LED,s http://holdenc.altervista.org/rpp/
- Banned
- Call Sign: KA5PIU
Re: Pic Programmer
Hello.
Although the Raspberry Pi looks neat, remember that ALL functions are done with 1 IC.
Want good throughput on ethernet? throttle back on all other functions.
Things like TV sets have purpose built chips, and can do little more.
The Pi is so versatile as it has no one embedded purpose, not optimized.
With that said and an understanding of the limitations, pacing tasks works well.
Pick up a smartphone, it will pause if several tasks are presented but gives priority to the user, as it should be.
But, the Pi is cheap, and can do oh so much more than lets say a basic stamp.
I am elated to hear of someone who has the desire to experiment!
Thank you!
Thank you!
