Kenwood IF-10C ??
- Call Sign: RDX64
Kenwood IF-10C ??
Hello, does anyone remember the IF-10C TTL to RS232 conversion board for the Kenwood radios?
Apart from looking for one cheaper than the $80 one being sold now, I'm thinking of making one.
Big question is about the UPD8251afc chip - does this need any programming? I can see one for £4 on the bay.
- Call Sign: RDX64
Re: Kenwood IF-10C ??
Anyone?
I am not getting your point ...
- Call Sign: RDX64
This was the point, the 2nd was a bump.Mattylad wrote:Big question is about the UPD8251afc chip - does this need any programming? I can see one for £4 on the bay.
I'm getting very keen to start this as a project but need to know the essentials about the uart first.
Cheers,
M
- 14jt65
- Call Sign: F4IKA
I installed this IC10 on my TS440S for CAT control. This is very easy to do. Bought 2 IC's on the web and just install those on socket, nothing else - no need to programming anything-
You have to add a cable from rig to computer .
Computer connection can be done on USB, in this cas you have to install driver to add virtual USB to RS232. this driver is easy to find. You can also choose cable connected RIG to computer RS232 (SUBD9) in this case nothing else to do.
If you need help I can search where I bought the IC's and the price I paid for it.
You can find a very interesting web page here: http://hamprojects.blogspot.fr/2012/08/ ... od-ts.html
FT950 & FT847 + Vertical Prosistel 1524 10, 15, 20, 40 m ; G5RV V inverted 80 & 160 m
Mainly QRV digimode
Mainly QRV digimode
- Call Sign: RDX64
THANK YOU!14jt65 wrote:I installed this IC10 on my TS440S for CAT control. This is very easy to do. Bought 2 IC's on the web and just install those on socket, nothing else - no need to programming anything-
This is what I have been after, if the IC needs programming.
I'll get one now and start a new circuit diagram in CADSTAR to make a board, I could use veroboard etc but I want to make it a decent job.
Once I have the IF-10C sorted then I think its pretty simple to connect it to one of the many 232 to USB adapters I can get on ebay.
- 14jt65
- Call Sign: F4IKA
No problem mate you'r welcome.
Depending whitch rig you have the kit may be different .
For. My ts440s it was 2 ic's intel 8251a and tc4040bp it's IC10 Kit , in yo message you wrote about IF10-C I think it's better to confirm these 2 kit are similar
When I installed my kit no need anything else than the IC and the cable with converter ttl/rs232 include inside USB connector for sale on Ebay around 13 pound .
73
Joel
73
Joel
Mainly QRV digimode
Mainly QRV digimode
- Call Sign: RDX64
Mine is the TS-680S so needs the PCB, but if yours did not need the chip programming then I suspect mine wont either.
This has been the big problem, in finding out because of the age of these radios.
Cheers.
Cheers.
- 14jt65
- Call Sign: F4IKA
Yes, TS680S need a board call IF-10C with wired connectors, it's the same for TS140.
I will have a look on TS680S modifications on the web.
If I found something interesting I will shere the links.
73
Joel
73
Joel
Mainly QRV digimode
Mainly QRV digimode
- 14jt65
- Call Sign: F4IKA
Here some interesting links if you really buid yourself the board.
http://www.hamradio.cc/forum/index.php?t=msg&goto=43
http://davor.bizhat.com/slike%202013/IF ... Schema.png
And Finally ...
http://www.piexx.com/index.php?main_pag ... ucts_id=21
It's up to you
And Finally ...
It's up to you
Mainly QRV digimode
Mainly QRV digimode
- Call Sign: RDX64
I have all those ta.
The tinternet has been scoured lol
Colleague at work has also confirmed I dont need to program the chip, and that I have been watching a completely different chip on ebay lol
- 14jt65
- Call Sign: F4IKA
Perfect then now you have all informations you need, it's time to made a good job
Good luck
73
Good luck
73
Mainly QRV digimode
Mainly QRV digimode
- Call Sign: RDX64
Cheers, will be posting Gerbers etc when finished - just in case someone else gets a 20+ year old radio and needs to mod it lol.
