Programming Software for Icom IC-F1010
- Call Sign: M6BYS
HI,
I have an Icom IC-F1010 and looking for the programming software for it, as there is a few channels I need to add. I can get the cable just need the software.
- kingkey
- Call Sign: G8NXV
Re: Programming Software for Icom IC-F1010
I have the software you need. I'll sent it to you on an email if you send me your address. I don't know any other way of sending it.
Best wishes
Ron
Best wishes
Ron
- Call Sign: M6BYS
- kingkey
- Call Sign: G8NXV
Software sent. Let me know if there is any problem.
Best wishes
Best wishes
- Call Sign: M6BYS
need help again lol, the cable I got to programme my F1010 is USB, but the com ports on the software say serial, i have tried changing the ports but still don't wont do ought, is there anything else I need to do or just get a serial cable.
- kingkey
- Call Sign: G8NXV
I just re programmed my F-1010 today. I use a PC with a proper serial port. USB to serial adaptors can be a problem.
If you need a circuit for the interface let me know but you will have to give me a couple of day's to dig it out.
- Call Sign: M6BYS
ok many thanks, will let you know
woud it be possible for me to get a copy of the software please, in real need of it cheers
- Admiral
- Call Sign: 26TM157
I cannot recommend or condone use of this site, but it may be of interest for educational purposes.
http://www.hackersrussia.ru/Radio/m_icom.php
Cheers for that but have tried that and the software wont connect to the radio, it wont read it, I have a USB cable to it and when it tries to read it i get a message saying something about a com port
- germanshepherd
That radio will be the vhf version of the 2010 in which case the software is DOS only and wont connect from a usb port and you will have to boot up from DOS (not a dos window).I tried to program a 2010 for a local guy but wasnt given the correct cable.
hello my name is Alfredo and I am try to set up a vhf repeater with two vhf Icom F1010 . I have received a program for this radio with cable in USB but it dos not work if it is possible a copy of the program so that I can set up a pc in dos with serial port and I also need the wiring diagram from the serial connector to the microphone connector thank you for your time Alfredo.
PS.My email ( [email protected] )
- Call Sign: 26IS001
Hi sir could I have a copy this software please pleasekingkey wrote:Software sent. Let me know if there is any problem.
Best wishes
[email protected]
All the best
Ian
kingkey wrote:I have the software you need. I'll sent it to you on an email if you send me your address. I don't know any other way of sending it.
Best wishes
Ron
Good morning. I know this post is old but I just purchased one of the f1010 and need the programming software as well. Can you please send itand any instructions you might have to:
[email protected]
Thank you very much
- Admiral
The person in question hasn't logged in for two years, so don't hold your breath.
