Hi Guys,
Although a newbie here, I have been listening on Airband for many years. I have a home brew synthesised Rx's dating from my Days at Ambit International in the 70's which still works very well. Based here in Chelmsford I am able to hear EGSS very well and also EGLL director and approach on 119.725 and 120.40 using a high outside antenna.
I recently purchased an Eton Satellit 750 to further enhance my listening and it's cr*p. Problem is simply that you cannot change the B/W in Airband mode to wide, and the narrow bandwidth is too narrow (7KHz ??) As you perhaps know, many channels in the London area are using a Tx offset. For example 118.825 hears the A/C but I have to retune to 118.830 to hear LATC's side of the transmission. Then you miss the A/C again !
I want to buy a UBC3500XLT and suspect this will be fine, as is an IC-R5 that I currently also have - but try as I might I cannot find any bandwidth figures given in the Uniden data. So hopefully you guys can put my mind at rest and confirm that you all hear both sides of the conversation.
I'm also playing with SDR Airband radios and this shows the offset Tx frequencies easily on the waterfall display..
John
UBC3500XLT
- Glamdring
Re: UBC3500XLT
I use a 3500 and have no issues. Go for it dude!
...and welcome to T1
- Minus1
Re: UBC3500XLT
The UBC3500XLT only has one AM bandwidth, and it's 25 kHz. I'm not aware of any commercially available scanners that do 8.33 kHz channelling properly. You just have to put up with the compromise.
Re: UBC3500XLT
iv got a icom ic-r3 scanner i want to swap for a ubc 3500 if anyones interested
ic-r3 covers everything up to 2.6ghz and has a built in lcd tv
http://www.universal-radio.com/catalog/ ... /3333.html
cant stand IGNORANT b******ds
- stu
- Call Sign: MM6HZA
Re: UBC3500XLT
Ive got the UBC 3500 too and it works very well for me too - give it a shot
DX:Tecsun S2000,Tecsun PL660,Tecsun PL310-ET,Sony SRF-59, Degen DE1103,Wellbrook ALA1530LN
Scan:Uniden UBC3500XLT, Yaesu VR120D, TSC-100R
Ham:Baofeng UV-5RE, Baofeng GT-3TP
Re: UBC3500XLT
The 3500xlt does do 8.33
Freq: 25 - 1300 MHz
Memories: 2500 Dynamic channels
10 Programmable search banks
3 Selectable Band plans
Air band search - pre programmed
Close Call™ RF Capture facility
Close Call - do not disturb function
Quick Keys
6.25 and 8.33 kHz Airband steps.
CTCSS and DCS Squelch
Lockout Function
Alarm function
Repeater function
Automatic Channel Steps
Scan delay Function
Custom Screen
Quick Recall
Alpha-numeric Tags
Data Skip
Auto Store
Batteries save function
Cloning Function
SMA-Antenna
Channel Hold Function
AGC-Function
Display Contrast Control
So does the aging Aor AR8200 Mk III
http://www.aorusa.com/receivers/ar8200mk3.html
Freq: 25 - 1300 MHz
Quick Keys
Lockout Function
Alarm function
Repeater function
Scan delay Function
Custom Screen
Quick Recall
Alpha-numeric Tags
Data Skip
Auto Store
Cloning Function
SMA-Antenna
AGC-Function
- Minus1
Re: UBC3500XLT
It 'does' 8.33 in the sense that you can tune in 8.33 steps and key in 8.33 frequencies.DuncanM wrote:The 3500xlt does do 8.33
But it does NOT 'do' 8.33 kHz bandwidth. It only has one AM bandwidth, 25 kHz.
So if you tune to an 8.33 freq that has 8.33 channels on adjacent frequencies, you will hear all three channels.
Fortunately there aren't many examples of such adjacent 8.33 channels.
