Hi I don't know much about air band but enjoy listening to air traffic. I understand that their is a military air band frequency between 230MHz - 400MHz why don't air band scanners have those frequencies available? Are those frequencies still in use?
I also listen to a HF frequency somewhere around 17MHz I can't remember the exact frequency but its a Volmet broadcast witch is repeated on some other frequencies. I'd really appreciate it if somebody could give me a complete list of all the Air Band frequencies HF/VHF/UHF.
I'm also interested in obtaining a home-base Air Band receiver "preferably something 1980's vintage looking" but have no idea of makes or models of any. The batteries in my scanner don't last for long
Air Band & scanners.
- liamcarbin
Re: Air Band & scanners.
Yes these freqs are still in use. You will need a scanner that can receive this band to listen to them.work wrote:Hi I don't know much about air band but enjoy listening to air traffic. I understand that their is a military air band frequency between 230MHz - 400MHz why don't air band scanners have those frequencies available? Are those frequencies still in use?
Volmetwork wrote: I also listen to a HF frequency somewhere around 17MHz I can't remember the exact frequency but its a Volmet broadcast witch is repeated on some other frequencies. I'd really appreciate it if somebody could give me a complete list of all the Air Band frequencies HF/VHF/UHF.
125.725 Scottish Volmet
126.6 London Volmet North
127.0 Dublin
128.6 London Volmet South
135.375 London Volmet Main
(HF)
3413 Shannon
5505 Shannon
8957 Shannon
13264 Shannon
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
- RogerD
Hi
To answer your first Q)
A) the 230-400 'mil air' band is seen as more of a niche specialist area of the hobby by scanner manufacturers.
It's more expensive to add it,
it's difficult for newbies for various reasons (including : there's less traffic, it's harder to find stuff, you're not 'supposed' to be able to find frequencies published, etc),
and the authorities of most countries would frown upon people intercepting mil radio traffic.....
- so it doesn't tend to end up on 'banded' receivers, only the wide continuous coverage ones.
HTH
HTH
- RogerD
Does it have a plug-in power socket?work wrote:I'm also interested in obtaining a home-base Air Band receiver "preferably something 1980's vintage looking" but have no idea of makes or models of any. The batteries in my scanner don't last for long
The old Realistics make good base scanners, something like a Pro2006 or Pro2042 would suite your needs and should probably be picked up cheap enough.RogerD wrote:Does it have a plug-in power socket?work wrote:I'm also interested in obtaining a home-base Air Band receiver "preferably something 1980's vintage looking" but have no idea of makes or models of any. The batteries in my scanner don't last for long
I tend not to use the power pack with my handhelds, I find they pick up too many spurious freqs running on mains for some reason. I use Duracell/Energizer 2450`s with the Energizer 1 hour charger.
Realistic pro2006, realistic pro2042, Yupiteru 7100, Fairmate HP2000, Degen 1103, ubc3500xlt, Micro-Adsb, Funcube Pro+
I have a Grecom PSR 295. It's not in the least retro but it does cover the military freqs.
I have a PSR 295 and it would be ideal for your needs
PSR295 SBS1er Auroa ssx Bct15x
- Beefeater
- Call Sign: TM727
I also have a PSR295 with mil band and various accessories inc PSU which i will be looking to sell if you are interested.PM me for more details if interested
Yaesu FT-840
Motorola GP-340 x2
Icom IC-735 Transceiver
Baofeng A58S Transceiver
Various Vertical Antennas x6
Motorola GP-340 x2
- Beefeater
- Call Sign: TM727
What a c--k up i made,just seen date of original post,so might advertise them in for sale section
Yaesu FT-840
Motorola GP-340 x2
Motorola GP-340 x2
