Sembcorp utilities
- bpoolfc95
Sembcorp utilities
Hi all, ive recently just inputed sembcorps freqs into my scanner along with the fire handies. It sounds like sembcorp have gone digital as two of there freqs are sounding digital. Has anyone recently heard them and do you think you could pick them up around Sunderland. I hope they havent gone digital and it seems daft if they have.
- bpoolfc95
Re: Sembcorp utilities
I wonder if its anything to do with the solar flare.
- liamcarbin
I've had to turn my scanner off today, too many freqs getting interference and needing to be locked out!!
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
i still get them on 443.1375 here in loftus
Sebcorp? what site? I have one of those here on teesside, they use a trunked net in the 44x area and I think they`ve got conventional pmr repeaters either onsite or up on eston nab (cant remember if it is at eston nab or onsite and cant check the wtr at the mo)bpoolfc95 wrote:Hi all, ive recently just inputed sembcorps freqs into my scanner along with the fire handies. It sounds like sembcorp have gone digital as two of there freqs are sounding digital. Has anyone recently heard them and do you think you could pick them up around Sunderland. I hope they havent gone digital and it seems daft if they have.
26TM234
- bpoolfc95
Yes the Teeside site(s). I think ive picked them up once and that was months ago. I hope im not just out of range as im not far from sunderland.
WOW!!!!!!bpoolfc95 wrote:Yes the Teeside site(s). I think ive picked them up once and that was months ago. I hope im not just out of range as im not far from sunderland.
I`m not far from them and I have problems getting them some times lolol
That said, I sometimes get a control channel for the busses from sunderland way every now and then
26TM234
- bpoolfc95
Smoggy, whats the freq for the buses you get. I cant input some bus freqs on my scanner as they arent cover in bands.
It`s 202.462500 (if it doesnt fall in one of the scanners 'gaps')bpoolfc95 wrote:Smoggy, whats the freq for the buses you get. I cant input some bus freqs on my scanner as they arent cover in bands.
you might hear control channel then it`ll die and the bloke will talk then the control channel will come back again (if it`s the one I`m thinking of so it maybe a single channel trunk, may not)
[EDIT]
it is a single channel trunked system
Code: Select all
Details for licence number 0067025
Start a new licence search
Licence holder details Licence holder Wear Buses
Contact name Company Secretary
Telephone 01914205050
Email
Address 117 Queen Street
GATESHEAD
NE8 2ST
Licence details Licence class Business Radio (Technically Assigned)
Frequencies and locations
Location(s) Channel(s)
NZ 183 476 TX: 202.4625 MHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
Code: Select all
Details for licence number 0045927
Licence holder details Licence holder Go Ahead Northern Limited
Contact name Mr Kevin Carr
Email [email protected]
GATESHEAD
NE8 2UA
NZ 271 593 TX: 202.4625 MHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 TX: 202.2625 MHz
RX: 194.2625 MHz
Bandwidth: 12.5 kHz
NZ 184 474 TX: 201.8625 MHz
RX: 193.8625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 TX: 206.1625 MHz
RX: 198.1625 MHz
Bandwidth: 12.5 kHz
NZ 271 593 TX: 205.7125 MHz
RX: 197.7125 MHz
Bandwidth: 12.5 kHz
RX: 194.4625 MHz
Bandwidth: 12.5 kHz
RX: 194.2625 MHz
Bandwidth: 12.5 kHz
RX: 198.1625 MHz
Bandwidth: 12.5 kHz
RX: 197.7125 MHz
Bandwidth: 12.5 kHz
26TM234
- bpoolfc95
Hi all, ive picked sembcorp utilities up tonight quite a bit. It was about half past 6 and they were doing radio checks and i heard them talking to an ambulance. At least i know im not to far away. Im amazed at how far i am and how clear i can hear them.
