Wire Rope
Wire Rope
Im after a reel of 100m or so of 4mm Galvanised Wire Rope for a crank up mast. Any suggestion of a good place to get it? Ive tried a couple and they have both quoted an outrageous figure for a courier to Jersey when they could use royal mail as they do for the mainland, at exactly the same price.
Second hand would be fine as long as its structurally sound.
Thanks in advance.
Thanks in advance.
- flickpot
- Call Sign: 163TM230
Re: Wire Rope
There's some on ebay linky http://cgi.ebay.co.uk/100-Metres-4-6mm- ... 53e2684add
but not sure mate about there postage charge.
163-TM-230
163-FB-230
163-FB-230
- dcwuk
Re: Wire Rope
Are there any electrical contractors/wholesalers around?
Ask for catenary wire
dcw
dcw
Re: Wire Rope
Ive tried them, they want more than £40 for postage on a £25 product.flickpot wrote:There's some on ebay linky http://cgi.ebay.co.uk/100-Metres-4-6mm- ... 53e2684add
Re: Wire Rope
how do you pronounce that? i dont want to look like a complete idiotdcwuk wrote:Are there any electrical contractors/wholesalers around?
dcw
- dcwuk
Re: Wire Rope
cat teen arry
- flickpot
Re: Wire Rope
NoiseBoy wrote:Ive tried them, they want more than £40 for postage on a £25 product.flickpot wrote:There's some on ebay linky http://cgi.ebay.co.uk/100-Metres-4-6mm- ... 53e2684add
Now that is taking pish £ 40 quid hope they platt the wire as well for that dosh....ffs
163-TM-230
163-FB-230
163-FB-230
Re: Wire Rope
Noiseboy.
It is only a suggestion,but have you tried any of the ships chandlers/marine supplies in the C.I
Regards,John.
Regards,John.
Re: Wire Rope
I didn't think of that John, i suppose they use it for mast stays and things on yachts?
Re: Wire Rope
Noiseboy.
It might be worth a try regarding the marine supplies.Failing success in the C.I,you could pop across to St.Malo.It would be day out for you.
Rope & Rigging
We stock all sizes of 3-strand, multi-plait, braid on braid, and Dyneema advanced ropes in a range of colours, all of which can be supplied with splices if required. You will also find a selection of light gauge stainless steel and galvanised rigging wire and a selection of thimbles and shackles. See our rigging loft for larger orders.
St.Helier.......http://www.southpiermarine.com/document ... isure_Shop
A place in Sussex is charging £51 for a 100 mtrs of 4 mm lashing wire rope,plus P&P
http://www.aerialsuperstore.co.uk/galva ... -538-p.asp
Or would 2mm wire be to small for you,200 mtrs for £14.95 plus P&P.This I presume would be of no use in the winch,but could be used as guy wires.
http://www.horseboxandtrailer.co.uk/Oth ... 574027.htm
Regards,John.
Rope & Rigging
Regards,John.
- ColinTelford
Re: Wire Rope
I get all my rope and gripples for lighting installs from here
http://www.zincomids.co.uk/products.asp ... oductid=12
100m of 4mm is £29 delivered.
Edit: sorry just noticed where you are, that price is Uk mainland.
