Active in the Doncaster area this morning, not quite sure whether it's the local council/builders/couriers, picked up a conversation about where a dept of the local hospital was, then shortly after about picking up stone.
Very good morning this with several new frequencies to me picked up, will have to try early in the morning more often, the others:
167.20000 & 170.82500 - unclear, one referring to 50mph winds, possibly working high up
167.70000 - only heard one side of the conversation, taking binoculars mentioned if that's of any use (probably not)
Annoyingly I picked up two radio broadcasts around the 60-70mhz range - one of which was German and the other English but unidentified (interviewing a couple of Politicians, radio 4 style) - but didn't note the exact frequency down
Oh, and one of those baby monitor things which was active at numerous points between 87 & 40 mhz (the same one)
164.66250 + a couple of others
- Tracked
- lincs_radio
Re: 164.66250 + a couple of others
WTR Search Results for Doncaster Area...
164.6625:-
WTR#: 0078373
Licencee: Mr Nicholas Dando
TX-Location: Hemsworth
TX: 164.6625 MHz
RX: 160.1625 MHz
(sorry, would have looked up the others for you but the wife is giving me orders...)
164.6625:-
WTR#: 0078373
TX: 164.6625 MHz
RX: 160.1625 MHz
LincsRX
Nick Dando is a local radio dealer up here, may be one of his CBS's
YB135
- Tracked
lincs_radio wrote:(sorry, would have looked up the others for you but the wife is giving me orders...)
No worries, thanks
- Admiral
- Call Sign: 26TM157
Obviously if it's a community repeater you can have several different low use companies on the same frequency with different CTCSS.
