Lincolnshire County Council Trunked Net
- lincs_radio
For a good few months now i've been monitoring what seems to be a Trunked Network on Control Ch: 179.1250
Licenced to Lincolnshire County Council... (WTR:0269983)
Just... i've NEVER heard any comms on any of the frequency channels
Also, im not sure what kind of Trunked System it is, its not MPT-1327... ???
(altho i does sound alittle like mpt1327 just with a higher baud rate??)
A few weeks ago one of the channels fired-up, but no voice/data comms...
thats the only activity i've noticed.
Just wondered why the council have this system if they dont use it?
The TX is just outside of Grantham, on the mast next to GB3GR...
Any Idea's ??????
Any Idea's ??????
LincsRX
Re: Lincolnshire County Council Trunked Net
it could be used just for data to send jobs to electritions or joiners and the like or even for vehicle tracking
next time you see a council van with a man in, ask him if they use radios and what they use them for lol
26TM234
Hi,
The net is used for RTPI at bus stops, currently in the Lincoln area with a proviso for Scunthorpe, Grimsby and Grantham areas. The data is as far as i understand a mixture of GPS and various modes similar to the bus stop info on the SY-WY Busnet.
Rgds,
alan
Rgds,
alan
- lincs_radio
Ahh, Excellent Stuff...
I did wonder if that was the kind of use (data), but you never really know unless you ask
Kind Regards,
Jayme
Kind Regards,
Jayme
LincsRX
No problem. I had been studying the busnet for a few years and the normal mpt1327 data is there on the controller freqs but when it comes to the interleaved data for the bus movements etc, then we are in wonderland.
Where in Lincs are u ?
Alan
Alan
- Call Sign: Rich
Hi,
I think the system is non-trunked conventional channels with some kind of FFSK signalling and voting. Voice comms. seem very limited, possibly just to one small operator, although all buses fitted have a Tait T2000 radio and mic which interfaces with a rather ancient Data terminal.
As said, the system is purely for passing GPS data and Sign Stop info for Real Time Passenger Information.
One interesting development however is the seemingly recent addition of another site to the licence at Gainsborough. Nothing is on air yet and I can't really find the site on Google Earth as the grid ref puts it in an odd location.
SK 809 882 TX: 179.525 MHz
RX: 187.525 MHz
Bandwidth: 12.5 kHz
SK 809 882 TX: 179.85 MHz
RX: 187.85 MHz
Bandwidth: 12.5 kHz
SK 809 882 TX: 177.3125 MHz
RX: 185.3125 MHz
Bandwidth: 12.5 kHz
RX: 187.525 MHz
Bandwidth: 12.5 kHz
RX: 187.85 MHz
Bandwidth: 12.5 kHz
RX: 185.3125 MHz
Bandwidth: 12.5 kHz
Rich
Hi,
Its at the end of Carr Lane in gainsborough, next to the river.
Alan
Alan
- lincs_radio
Hi ANCIENTMARINER,
Im from Sleaford, which is around 19 miles south of Lincoln.
LincsRX
- Call Sign: Rich
It seems an odd place for a site as there are no masts around there and its at one of the lowest points in the area.ANCIENTMARINER wrote:Hi,
Alan
EDIT: Now found a commercial mast on Carr lane which is a candidate. Also seems to be a high building in as there's a Vodaphone 900 site listed as being 42m asl near the river.
Rich
- Call Sign: Rich
On a related note whilst looking for info on the RTPI system, I stumbled upon this.
http://www.vebra.com/property/20191/20046455
It's a mast and land which used by LCC for the Gainsborough gritting channel. After no activity at all on their Low band channels this winter, I can only assume that lincs have ditched their radios - seems mad to me.
Rich
- lincs_radio
So i wonder if you guys can help me again...
178.1625 MHz - WTR:0820520 - TX @ Stenigot...
Any Idea's...?
I had a quick search round the interweb, and the closest i could match the sound to is the old NMT-450/900 control channels????
Cheers!
Any Idea's...?
Cheers!
LincsRX
Its Fleetcomm Stenigot cc, mpt1327 system.
Alan
Alan
TF 257 825 TX: 178.1625 MHz
RX: 186.1625 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 179.9375 MHz
RX: 187.9375 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 181.475 MHz
RX: 189.475 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 178.0125 MHz
RX: 186.0125 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 180.4375 MHz
RX: 188.4375 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 181.025 MHz
RX: 189.025 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 178.3125 MHz
RX: 186.3125 MHz
Bandwidth: 12.5 kHz
TF 257 825 TX: 180.875 MHz
RX: 188.875 MHz
Bandwidth: 12.5 kHz
Stenigot Fleetcomms site channels as above.
Alan
RX: 186.1625 MHz
Bandwidth: 12.5 kHz
RX: 187.9375 MHz
Bandwidth: 12.5 kHz
RX: 189.475 MHz
Bandwidth: 12.5 kHz
RX: 186.0125 MHz
Bandwidth: 12.5 kHz
RX: 188.4375 MHz
Bandwidth: 12.5 kHz
RX: 189.025 MHz
Bandwidth: 12.5 kHz
RX: 186.3125 MHz
Bandwidth: 12.5 kHz
RX: 188.875 MHz
Bandwidth: 12.5 kHz
Alan
- lincs_radio
Just tried running it thru 'TrunkView' & 'TrunkSniffer' and nothing... ???
It doesnt sound like MPT-1327?
Audio Sample Below:
http://www.jayme.uphero.com/178.1625MHz_Stenigot.wav
Audio Sample Below:
LincsRX
- Call Sign: Rich
Hi, Each of Fleetcomm's three radio sites transmits this data on a separate frequency to the control channel. (Stenigot's control ch is currently 181.0250)lincs_radio wrote:Just tried running it thru 'TrunkView' & 'TrunkSniffer' and nothing... ???
Audio Sample Below:
Not sure what they are planning to use it for. If you scan 186-192Mhz you will probably pick up the origin of this data on the input too. I believe it's from the companies mast at their office in Goole, and being beamed to each site on a YAGI.
