Two Ariels off one plug
- Scott_93
- Call Sign: Sunray20Alph
So I have a Yaesu 8800 sat here in front of me that's capable of cross band repeat and has been free banded, anyway my question is how can I connect two different ariels to it (it only has one output socket) and let the science choose the best matched ariel to use. This is for using one frequency in VHF and one in UHF that aren't harmonically resonant so can't share the same frequency.
So is it possible?
And if so how ?
Scott.
So is it possible?
And if so how ?
Scott.
- bigpimp347
Re: Two Ariels off one plug
a switch box is the obvious way, but not sure if a duplexer will work in reverse..
why not just buy a dual band aerial, or a switcher box ??
- Scott_93
Has to be remotely switchable ie operate on it's own.
Can't use a dual band ariel as it's not in the ham bands, nor are the frequencies harmonically resonant.
Scott.
Scott.
- fez
surely the way he wants to use it is the norm?bigpimp347 wrote:but not sure if a duplexer will work in reverse.
Lots of people who work satellites use a duplexer for 2 antennas as the uplink and downlink are usually on different bands.
They also work both ways.
- bigpimp347
fez wrote:surely the way he wants to use it is the norm?bigpimp347 wrote:but not sure if a duplexer will work in reverse.
not sure if you can only use a duplexer one way, as in two rigs one aerial..
unless you can use one rig two aerials from one, never tried so don't know..
- Scott_93
Ah I forgot about that,fez wrote:surely the way he wants to use it is the norm?bigpimp347 wrote:but not sure if a duplexer will work in reverse.
So I take it the ariel that matches best is the one that gets the load then ?
Of course a SWR check will happen to make sure but in theory it would work ?
Scott.
- fez
Scott.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Duplexer
http://en.wikipedia.org/wiki/Duplexer
Diplexer
http://en.wikipedia.org/wiki/Diplexer
Wiki has a good explanation. Hope this helps and good luck
Diplexer
- Scott_93
Ah ha,
So a Duplexer allows a separate transmitter and receiver to share a common antenna whereas a Diplexer allows one transmitter/receiver to share two different antennas, usually one higher in frequency, one lower, both switched via a high-pass or low-filter.
It's starting to make more and more sense now.
So how would I make myself a Diplexer ?
(Please forgive my lack of knowledge, I'm only an intermediate)
Scott.
Scott.
- iansradios
Just give me the radio
- fez
search duplexer on ebay, Plenty for sale.
They print duplexer on them so thats what I call them. Will work for 2 radios 1 antenna or one radio 2 antennas.
http://cgi.ebay.co.uk/Diamond-MX-72N-Du ... uipment_SM
http://cgi.ebay.co.uk/MX-72-CB-Radio-An ... uipment_SM
