ft840 owners may like this resistor mod
Have you found an interesting radio related website? Don't keep it to yourself, post it in here. The best ones will also be added to the weblinks database!
andrew013
Call Sign: 26AT013
Post by andrew013 » 18 Aug 2014, 20:48
my trusty ft840 of 20 yrs just went and died on sat found out that resistor 2213 burns out and can kill the radio in many ways , mine had no display rx or tx but a quick look and seeing burnt /scorched circut board and the fact that the resisitor was dead i found this mod which should be done regardless (it has fixed mine good as new i got the resistor in the mod and cost £3.80 you can get cheaper alloy ones 2 for £1.88 etc )
http://www.na8y.com/2012/06/yaesu-ft-84 ... ement.html
