Is there an equivalent of Squelch-line on DMR ?
Rob Johnson
Post by Rob Johnson » 12 Jul 2016, 03:27
Hello All,
Is there a way of "picking-out" the equivalent of the squelch-line on a DMR radio, thinking of something like an MD785 here. It would be very useful for "cross-banding" (cross-technology-ing) between an analogue-mobile and a DMR-mobile radio. Could see nothing obviously marked when looking at a circuit-diagram of a DMR mobile earlier-on today. I did notice that there are "mode" and some other possible trigger-lines going to the audio-amplifier, if that's what they are. Do these lines carry-out "opening" the audio-amp up when a valid signal is received ?
Any information greatfully received. Thank you.
Rob.
Scott_93
Call Sign: Sunray20Alph
Re: Is there an equivalent of Squelch-line on DMR ?
Post by Scott_93 » 27 Feb 2017, 03:03
I think it's in the Hytera service manual. Yes there is such a thing. In fact you can wire a Hytera cross pins and use it as a cross-band repeater just off the bat and if you put it through a cavity filter as an in-band repeater too.
Scott.
Call Sign: G4RMT
Post by paulears » 23 Apr 2017, 20:31
I've been experimenting with an optometrist controlled relay I bought from aliexpress - little pcb, with a sensor on the end of a short cable - I blutacked this to the RX LED on a radio and it closes the relay. My idea was a dPMR repeater with a couple of hand held, but the two cycles of codec travel mean that the usual digital latency gets doubled, and the vocoder quality is slightly worse. I didn't want to have to open the up to do it properly - and the relay switch proved to be the simple bit!
Freddie
Post by Freddie » 03 May 2017, 22:03
paulears wrote:I've been experimenting with an optometrist controlled relay I bought from aliexpress
Why does your eye-doctor decide when the relay closes? :D
Call Sign: G4RMT
Post by paulears » 05 May 2017, 07:57
Never noticed that auto-correct - optometrist????? Letting the numpties at vision express run radios would be fun - took 3 optometrists to get my glasses prescription right!
Opto-isolated!
Rob Johnson
Post by Rob Johnson » 01 Jun 2017, 03:01
Hello All,
Sorry I have been away from here for a while and not replied to these informative posts. I will have a play with the MD785 that I have. I have now got the pin-out info for the 26 pin (why don't they use a NORMAL DB25 ?) on the back. Looks like the pin that does "speaker-enable" is the one to go for. I will report back. Thank you.
Rob.
