Dstar through samsung tab4
sec1223
Re: Dstar through samsung tab4
Post by sec1223 » 29 Jan 2016, 18:07
you will need SDRTOUCH for android, and the RTL2832U driver.... both off the play store
cant stand IGNORANT b******ds
Post by Admiral » 29 Jan 2016, 18:25
sec1223 wrote:you will need SDRTOUCH for android, and the RTL2832U driver.... both off the play store
Yup, that's what I have, but it won't decode D-Star unless they've done a massive upgrade since my version.
sec1223
Post by sec1223 » 29 Jan 2016, 19:31
ah... iv never used it for dstar admiral
kr0ne
Post by kr0ne » 29 Jan 2016, 22:55
Post by Admiral » 30 Jan 2016, 08:13
Thanks goodness there's no mention of 5¼ inch floppies.
MW6ZAN
Post by MW6ZAN » 30 Jan 2016, 11:32
Ok guys thanks im now completely befuddled. What mess around just to listen in, i think i shall have to consider as to which way to go with this take care best 73 :? :? :?
Post by Admiral » 30 Jan 2016, 12:04
If you are vehemently against Windows then you can use mbelib to compile DSD for Linux.
http://www.george-smart.co.uk/wiki/Digi ... ch_Decoder
Linux used to boast that it was light on resources and was better for older hardware, that's still true with some of the specialised distros, but the general Ubuntu and Fedora based distros are now as resource hungry as Windows is, if not more so in some cases.
kr0ne
Post by kr0ne » 30 Jan 2016, 12:31
The populust criticism of Windows has always been that it's large, bloated, contains a ton of unnecessary stuff, resource heavy, receives too many security updates, etc. etc.
The advantage with Linux is that you can build an extremely compact, fast and efficient system if you are that way inclined. Something that really isn't possible with Windows.
The thing is though, stripping out code from here and there and re-compiling kernels just isn't for most people, so the Linux based desktop (and server!) distros have really taken off.
As you've noticed though, if you create a distro that mum can install on just about any hardware out there and you include the software that the family need to make a computer useful......... you end up with a system that is large, bloated, contains a ton of unnecessary stuff, resource heavy, receives too many security updates, etc. etc.
bigbloke
Post by bigbloke » 03 Feb 2016, 22:17
Ok I havent read both pages of posts so sorry if I cover other posts.
There is currently no android capable app that can demodulate voice from a digital communications radio.
DAB ? yes (Wavesink Pro) but NOT DMR/D-Star/Fusion/IDAS/nexedge /p25
So what CAN you do with Android & Ham radio ?
You can use an external radio (i.e. handheld / desktop or mobile radio) to demodulate:
PSK31 (droid psk by wolphi) TX too
RTTY (Droid RTTY by Wolphi) TX too
CW (Morse decoder by Wolphi)
ACARS (author unknown)
SSTV (droid SSTV by Wolphi) TX too
WEFAX / HF FAX (HF weather fax for marine by wolphi or HF weather fax by black cat systems)
You can use an RTL chip based dongle with an android device via the USB "on the go" port to:
listen to about 25-1700 MHz, analogue modes (AM/FM/SSB/CW) with a visible spectrum of around 2MHz (SDR touch)
listen to HF in analogue modes by using an external up converter between the HF antenna and the RTL dongle , or a custom
dongle with the upconverter built in. (again the app you use would be SDR touch)
Listen to Broadcast FM, DAB and DRM transmissions (via an upconverter for DRM) using Wavesync Plus
Watch the position of overflying aircraft on a map by decoding the ADS-B radar responses on 1090 MHz (ads-b on android by unknown)
There are other ham radio apps that let you tune other peoples HF radios , listen to american scanners, and so forth, but they
have no "local" radio interaction.
Presently to listen to D-Star, to the best of my knowledge, you have two options:
A scanner with a discriminator tapped mod (easy) feeding a linux PC running DSD 1.7 or later (thats linux DSD not windows DSD / DSDplus) or
A dedicated and expensive ICOM radio.
its possible that GQRX can "pipe" audio into DSD 1.7 ? ive never done it so I cant answer honestly.
Now, on Windows you can use a virtual audio cable package to feed audio from a radio dongle programme into DSD for windows or DSDplus for windows and recover digital audio from a number of modes like DMR , P25 , Nexedge, but sadly none of the windows DSD/DSDplus apps currently
demodulate D-Star - they only display the signalling traffic (boring and repetitive in the extreme!)
I hope that clears up the current situation and removes ambiguity!
Regards
BB
