Procedure for lowering ssb output, ru mode jacko 2
original45
Call Sign: 45
Post by original45 » 14 Jun 2019, 19:16
One of my biggest bug bears ,no variable ssb on jackson 2 as with many I imagine.
Wish to lower ssb output to around 15 watts so able to run amp obviously in ru mode.
First issue, I don't have a pep meter ,just a standard cb swr power 10/100 watt pwr meter.
Can someone advise how best with this meter to get it close and its procedure.
Any specific block to adjust from , which pot for Ssb power.
Appreciate the guidance please.
14CS06
Re: Procedure for lowering ssb output, ru mode jacko 2
Post by 14CS06 » 14 Jun 2019, 19:38
Hello
Pot for Ssb power RT 202
http://www.cbradio.nl/president/Service ... er_ENG.pdf
original45
Call Sign: 45
Post by original45 » 15 Jun 2019, 11:00
Thank you Claude, presume anti clockwise to reduce sounds simple enough .
Appreciated
